Question about EliteGroup P6VXAT Motherboard
When i turn on my monitor display an error that no keyboard attach... i use usb type and ps2 type...
    New Friend:
    Problem Solver:
  • 8 Answers
Shut the PC down completely, Unplug all your USB and PS2 cables from the back and unplug the power cord. Check and make sure that the pins are not bent on the PS2 cable. Plug the power cord, USB and PS2 cables in and start the machine. If you still experience the issue repeat above shutdown procedure. Open the case and either jump the BIOs (see the manual) or pop out the Motherboard battery for a few minutes. This will reset the CMOS. Put it back together, start the computer and configure the CMOS (see manual or look for you tube video), if you don't have a manual than get the make and Model on the Motherboard, find the manufacturer website and download a manual. Good luck.
Posted on Oct 21, 2013
    Problem Solver:
  • 5 Answers
This one isn't easy but it might be a compatibility issue with the keyboard although ps2 keyboard are suppose to work 95% of the time there is still the possibility that your keyboard is not recognized or is defective, as for the usb, most pc's don't recognize it until it has time to install the drivers within windows, hope this helps.
When i turn on message display error keyboard...i use ps2 and usb type...
Is it working fine on USB Keybaord after removing the PS2 Keybaord ??
Oct 21, 2013 | Computers & Internet
How can I plug my laptop latitude d430 on a seperate samsung monitor using a belkin flip ps2 cable? ... is laptop is compatible with ps2? or should i need drivers for belkin or samsung monitor on the...
You need a standard analog video or DVI cable to attach the monitor.
PS2 is for your keyboard or mouse only. However, Belkin has a PS2 to usb adapter that will let you attach these devices to your laptop via USB if you need to.
Mar 17, 2010 | Dell Latitude D430 Notebook
Hello, i currently use a IBM desktop with IBM keyboard and mouse but i just bought a microsoft wireless keyboard and mouse which i just installed into my desktop using the installation CD. They are both...
Hi Tony,
It appears that you have an IBM desktop whose BIOS isn't capable of booting off of a USB keyboard and mouse device. Older computers used to require that a PS2 mouse and keyboard be attached before booting, to prevent you from booting a machine without any way of controlling it. You have 3 options:
1. leave the corded mouse and keyboard attached and never use them
2. update the BIOS for your desktop to the newest one in hopes that the updated BIOS will allow for USB mouse and keyboard operation
3. go to a computer store and get a PS2 to USB converter/adapter. They're small and relatively inexpensive. It plugs into the PS2 port, and makes your computer think that there's a PS2 device connected, when it's actually a USB device.
Mar 03, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
Will not post at startup but then vista login pops up can not go into bios because the keyboard does not seem to work until vista kicks in. says it is in the powersave mode but I have disabled it in the...
is it a usb keyboard? usb keyboard support is probably off in the bios, so it will not recognise it untill windows loads driver for it. if you have an older keyboard around with the old purple PS2 plug on it, that should work for you to get into the bios. then turn on USB keyboard and mouse support.
Nov 18, 2009 | Dell Computers & Internet
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
Hi!
Have you tried using or testing different keyboard?
Maybe your keyboard is diffective.
If the same problem.
Then your PS2 port is malfunctioning.
You can buy an USB Keyboard if available in your place or serial type keyboard as alternatives.
Nov 24, 2008 | AOC CT720G 17" CRT Monitor
Attach HP PS2 Keyboard to Dell Laptop
hmm, Interesting
Because the Laptops mostly do not have the PS2 Port,
if you are using the converters connecting the USB to the PS2.
then It may be the junction related issue.
so find a USB mouse and connect it directly or try with another Converter.
that should work.
Jul 15, 2008 | Computers & Internet
Keyboard not working
Hi abcd_21;
Is that a usb keyboard or a PS2 keyboard? if its a PS2
kindly Do these steps below:
1. remove keyboard PS2 from PC
2. restart PC, and observe if you see the error "no keyboard detected"
3. turn the pc off
4. attach the PS2 kayboard then Turn ON.
if its a USB:
1. remove usb
2. restart pc
3. plug the usb in when the pc has completely booted up.
4. wait for the found new hardware icon to detect your usb
Jun 05, 2008 | Dell OptiPlex GX260 PC Desktop
Belkin 2-port kvm switch
If you have the PS2 mouse and keyboard (round plug-in) instead of USB this is an easy install. however if you have USB you will need adapters to make this work, but I do not recommend it since more problems could occur. If you have the PS2 ends first shutdown both computers. remove your monitor, mouse, and keyboard from your computer and attach them to the single end of the switch. Mouse goes to Green, Keyboard to Purple. Take the other ends and connect the first group to your first computer mouse, keyboard, and monitor (same colors as above) and repeat for 2nd group of wires on 2nd computer. turn the computers on. you should get display, keyboard, and mouse for 1st computer. after both boot hit scroll lock 2 times within 2 seconds and then arrow up or down key to change between computers.
Oct 18, 2007 | Belkin F1DK102P 2-port KVM Switch
EliteGroup P6VXAT Motherboard Logo
44 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
