Question about Video Game Consoles & Games
How to set up my ps3 wired headset
It doesn't show my device
    New Friend:
Make sure you have set up the headset as both the input and output devices , then test if it works .
If it works in the test you might need to set up the voice chat settings in the game you have , some require setup for mic use so read the manual for your game and do any setup required
If your headset doesn't work in the test it might be broken , or you might just be underage and on a psn sub account which blocks most online features like chat
Posted on Oct 22, 2013
I recently purchased a new headset Called an X205 EA Sports USB Motorola Gaming Headset and I wanted to use it for my Playstation 3 and works fine for hearing but it won't transmit my voice at all it won't...
Maybe this helps:
USB Headsets
  • Through the USB ports on the front of the PS3 system, you may utilize a USB certified headset. Please note, although a headset is USB certified, it may not be recognized by the PS3 if it requires drivers for installation.
  • Devices that are approved for use with the USB ports of the PS3 system must either be made by SCEA or be USB certified. Typically, a USB certified product will have the official USB logo on the package, manual or on the "belly" label of the product itself.
  • To use a USB headset you will have to select it as the input and output device. To select the headset and make adjustments, go to (Settings) > [Accessory Settings] > [Audio Device Settings] option. Then you can use the headset with compatible PS3 format softwar
Jun 27, 2014 | Radio Communications
I am trying to hear my gameplay through my plantronics gamecom p90 headset i got the headset to work but i cant hear my gameplay through it
If your headset is the P90, turn the headset on. The light on the headset should start flashing red/blue. If it doesn't, start with the headset turned on, press and hold the call control button on the headset until the light on the headset starts flashing red/blue, red/blue. Follow the on screen instructions and let the PS3 scan for the headset. It will appear as "P90Plantronics" in the list of devices. If prompted for a passkey, enter 0000 (4 zeroes). Now go back to the Accessory Settings menu and then select Audio Device Settings. Select "P90Plantronics" as the audio input and the audio output device. You should be all set. If not, you can contact the Technical Assistance Group at 800-544-4660 x5538.
Good luck from Headsets Direct - 800-914-7996.
Aug 10, 2011 | Plantronics GameCom X10 Headset
My ps3 head set has said paired but not working , why . this 2 one ive got same problem.
The headset only works for games that support headset communication.
With that in mind, after you successfully pair a Bluetooth headset with your PS3, you need to verify that it's currently being used by the system.
- - - - - - - - - Skip this section if you've paired the headset already - - - - - - - -
To verify that the headset is paired, go to:
XMB (main menu) > Settings (second icon from the left) > Manage Bluetooth Devices (5th icon down) > [name of your Bluetooth headset] under Device Name with a blue dot next to it
-If you don't see your headset under there, select "Register New Device" on the bottom of the screen and follow the prompt
-If you see the device name, but the dot to the left of the device name is black and not blue, turn on your headset and on your PS3, highlight the headset device name and press the Triangle button and select "Connect"
Finally, to verify that your headset is being used by the system, go to:
XMB > Settings > Audio Device Settings (7th icon down)
From here, make sure that the Input Device shows the name of your headset's device name- if not, highlight Input Device and press Up and Down on your controller to select the headset.
Next, you will do the same thing for Output Device- select your headset device name if it is not shown.
Once your device name shows in both Input and Output Device areas, you can talk into the headset and you should be able to hear yourself. Adjust the microphone volume by changing the number next to "Microphone Level". The bars on the top of the screen in Audio Device Settings should move and respond to speaking into the microphone.
Finish by selecting OK on the bottom of the screen to save your settings. Don't hit the Circle button or else the changes may not save!
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
I tried to connect my emerson 227 bluetooth to my ps3. it tells me to press the start button and enter button on the device at the same time and wait until the screen changes.. well it never changes.. what...
Pairing the Headset with a Sony Playstation3 Entertainment System:
To pair your [EM-227] Bluetooth Headset with the Sony Playstation3 (PS3), go to the PS3 main menu, scroll to "Settings" and select.
Scroll to "Accessory Settings" and select.
Scroll to "Manage Bluetooth Devices" and select.
The menu will ask: "The Bluetooth device has not been registered. Do you want to register it?"
Select YES.
Put your [EM-227] Bluetooth Headset into discover mode (see X.XX of this manual for instructions on how to get the headset into discover mode).
Select "Start Scanning" from the PS3 menu.
Once the PS3 has discovered the [EM-227] Headset the screen will read "Select the Bluetooth device to register".
Select [EM-227].
The PS3 will ask for a passkey. Enter [0000] then press "OK".
Now press O (the PS3 circle button) to get back to the previous menu.
Scroll to "Audio Device Settings".
Change the "Input Device" to [EM-227].
Note: "Input Device" is the microphone, how others will hear you speak.
By default, the "Output Device" will now switch to [EM-227].
Note: "Output Device" is the audio, how you will hear the PS3 audio and others speaking.
If you would like to hear the PS3 audio and others speaking through your TV or Audio System, scroll to "Output Device" and switch to "System Default Device". If you would like to hear sound through the [EM-227] headset, then leave the "Output Device" setting on [EM-227].
To test your connection, speak into the headset and you will see the bars above the "Microphone Level" moving. If not, repeat the pairing process.
Press "OK" to confirm the new settings. You are now ready to use the [EM-227] Bluetooth Headset with your PS3 Entertainment System.
For further assistance with Bluetooth settings on your PS3 please refer to your PS3 instruction manual.
Oct 06, 2010 | Samsung WEP200 Headset
Cant pair ps3 wireless headset
sometimes it is easier just to watch a video!
Here ya go. please remember to leave me a positive rating and a testimonial really helps!!
thank you!
1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions (1.0, 1.1, 1.2). 2009 may see version 2.1 Bluetooth headsets hit the market, so you will have to try it for yourself on PS3.
  • All brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
  • Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
  • Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
  • The headset should be set as the input/output device from the XMB.
  • For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
  • For USB users, make sure the connection is secure and there are no wire breaks.
  • Update your console to the current available firmware.
Pairing Problems:
  • If the PS3 cannot locate your headset, make sure that your headset is in pairing mode before you start scanning. The headset instructions will tell you how to set yours to pairing mode.
  • If your headset is missing from the device menu after you re-start your PS3, you will have to pair again. Many headsets will only "remember" one device at a time, so you may have to register again after using your headset with a phone.
  • If your headset appears on the Audio Device menu but is "grayed out" or not selectable, it is not connected. Make sure the headset is charged, and that it is on in standby. I should connect automatically when the Audio Device menu is selected. Tap the call button on the headset if it does not connect, or click on the Connect Bluetooth tab on screen.
  • Make sure no other Bluetooth devices are in use nearby.
Voice Chat Drops:
  • Most in-game voice chat drops are simply network lag. Usually they go away after a short time, so be patient. In extreme cases you may have to leave a game and return to reset the chat function.
  • If you use wireless internet, a low signal strength to your modem/router can make voice chat malfunction. Make sure your wireless signal is as strong as possible to your access point.
  • Sometimes a headset will quit after changing discs to another game. Go to accessories and select your headset again.
4. Playstation 3 Links and Customer Support:
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
How can i attach a bluetooth to ps3 plz help
Hello my friend this should help you out.
please remember to leave a positive rating for me and a testimonial if I helped you out!
Bluetooth:
USB:
2. Setup
and here's a video in case you are a visual learner.
Mar 26, 2010 | Sony Video Game Consoles & Games
Trying to hook my bluetooth headset to my playstation three what do i need to do
Bluetooth Headset Setup
In Game XMB:
All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
Video Walkthrough (thanks jonny k)- http://www.youtube.com/watch?v=8tSItLGLsX8
Playstation 3 Users Guide- http://manuals.playstation.net/document/en/ps3/current/index.html
Feb 06, 2010 | Samsung WEP460 Bluetooth Headset
Using PS3 Sony Wireless Headset with EndWar game
Go to "settings" on your XMB (cross media bar) scroll down to "Accessory Settings" then scroll down to "Audio Device Settings" and make sure your "Input/Output Device" is using "Wireless Headset".
Apr 26, 2009 | Ubi Soft Video Game Consoles & Games
Am having problems with setting up my bluetooth headset for ps3
the problem of it is compatibility here's the step1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions.
  • All makes and brands of Bluetooth headset should work with the PS3.
USB:
2. Setup
  • Set the "Microphone Level" to 4. You can change the level any time if needed.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works. I will add info on that as it comes in.
In Game XMB:
  • All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
3. Troubleshooting
General:
Nov 13, 2008 | Video Game Consoles & Games
Using Motorola Blue Tooth with PS3
Yes you can. Just go to accessories or audio device settings. Have your headset on and hit connect bluetooth device. The key it asks for should be 0000. If that doesn't work do a quick search online and you should be able to find one that works.
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
69 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
