Question about Garden
Wheelhorse toro riding mower will not start, was mowing, shut it off to take a break, went to start again, nothing, will not turn over, spark plug is good, gas is good, oil is full,
    Problem Solver:
  • 16 Answers
Use a multimeter to check battery voltage. You may have a bad battery or alternator circuit problem causing it to fail to recharge. You might try jumping it with jumper cables from a car/etc 12V battery.
If this does not help, also check the switch under the seat as some are wired so that you have to be sitting to run it and if that switch fails then the design assumes you aren't sitting on it.
Posted on Oct 21, 2013
  • 4 Answers
SOURCE: 2007 Toro LX 425 Riding Mower, slow cranking.
check the starter see if it is going bad or not?
Posted on Apr 18, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
Posted on May 22, 2009
  • 376 Answers
SOURCE: Murray riding mower won't start
Sounds like a defective starter solenoid.
Posted on Jun 18, 2009
  • 138 Answers
SOURCE: craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Posted on Aug 17, 2009
  • 57 Answers
SOURCE: My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Posted on Apr 04, 2012
Testimonial: "I finally got it started after draining the gasoline out and replacing with new gas. It only runs with the choke engaged, but I'm going to seafoam the carburetor and add it to the gasoline."
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 | Echo Garden
Manual to show how to change head gasget on toro wheelhorse ride on mower 110-4
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual..
Jul 02, 2011 | Toro Garden
Hi have a Toro wheelhorse 212-6. new to us. wont cut.
Yes, there is a switch on the dash. It operates an electric PTO or clutch for the mower blades. That is how most lawn tractors work. Of course , yours could be different, but if it is, It still has a clutch somewhere and a lever to engage the blades. Most of the electric ones are controlled by safety switches, One being in the seat, if you are not in the seat, it will not connect, if you get out of the seat with it running, the engine will cut off. Sometimes one is on the mowing deck, it will not connect if the deck is up. If you cannot get the PTO to work, it could be shot. (Rare) You can hear it go when it starts, check it out, hope this helps.
Jun 06, 2010 | Garden
I need a owners manual for a Toro Wheelhorse tractor model 16-44 HXL
simple go to outdoorpowerequipment.com and enter make and model and you can download or print it in pdf form
Aug 27, 2009 | Garden
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
