Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemini freestanding range plastic leveling legs are bent, they were caught on the edge of vinyl floor, and forced. I know they have replacement parts for them, but my flooring contractor says the holes where they screw in on the bottom panel are also distorted. He suggested putting pieces of 1 x 4 wood under the range, and just removing the leveling legs. Is this a bad idea?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Not a bad ides, but you might be able to screw the leg back in and then bend it to a straight and level position.
Posted on Oct 21, 2013
SOURCE: Maytag Gemini MER6772 keypad/ovens not working
I had same problem, error code F 1-8, shorted keypad. I was so frustrated I went ahead and tore it apart. There was a surprising amount of gunk and moisture between the plastic face and the actual contacts. I cleaned it up and let it dry out. It worked OK for a while, but the seal is not good, and moisture from baking is still getting into it. When it goes bad again, I'm going to take off the plastic face and just press the sensors with a pencil eraser. I'll probably replace the range within the year. No way I'm paying $385 for new pad + installation on 10 year old stove.
Posted on Jan 03, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag MGR5775QDS Gas Range Control Panel Problem
sure you can relace yourself, the part number, if you dont already have from previous repairs can be obtained fromthe sears website, or by calling manufacture direct. as far as a schematic there should be one located behind the range.
Posted on Feb 21, 2009
buffalonyman
  • 1865 Answers
SOURCE: I have a Maytag Gemini double oven with a gas
18" is standard
Posted on Apr 16, 2009
SOURCE: Maytag Gemini oven glass door panels impossible to clean
We had an ugly spill of hot grease/water from a roast, and lots of it ran right into the vent holes on our oven door, covering various layers of glass and other parts inside the door. Yuck. Thankfully we found this site!
"fixetheoven" was certainly on the right track, but missed a key step that makes this job much, much easier. (Maybe they had a few too many sips of wine during the process?! :-)
Anyway, the key to make the job easy, and do-able by one person, is to pull the door off the hinges before starting to remove any screws! Here's how we did it:
1. Open the door about four inches or so, it will stay in place. Hold the door at the sides and lift it up, sliding it right off of the hinges! Now lay it carefully face up on a table so you have easy access to the screws, and no danger of the glass dropping out of the bottom of the door (as apparently happened to "fixedtheoven".)
2. Remove the two screws that hold the panel on one side of the door. (One screw is halfway up the side panel, the other is on the bottom edge of the door.)
3. Slide the panel off, paying close attention to how it fits into place so you can return it to its original position later!
4. Remove the two screws that hold the panel on the other side of the door, and slide that panel out as well.
5. Remove the three screws that hold the panel across the bottom edge of the door, and remove that panel.
6. Now you can slide the front glass out from under the top edge of the door.
7. Clean the front glass, the side panels, and the bottom panel, as needed.
8. There will be another layer of glass inside the door. If it needs cleaning on the underside, remove the screws from one of the metal brackets that hold the glass in place. You can then slide this piece of glass out from the metal bracket at the other side.
9. After cleaning everything, reassemble the door by reversing the above steps.
10. Lift the door by the sides and carefully slide it back into place on the hinges. Be sure it is properly in place and being held there before you let go!!
11. Now go pour that glass of wine and sip to your heart's content, while admiring how clean your oven door is!
Posted on Jul 29, 2009
milten1
  • 1304 Answers
SOURCE: I want to remove the cook top off my Maytag Gemini
there are two very small screws on the corners above the door, some times more along the whole front
once removed your top will flip right up
Posted on Oct 03, 2009
Maytag gemini range
Don't keep resetting the breaker, you have a dead short and you could burn your house down, call an electrician.
Jul 22, 2016 | Maytag Gemini 30" Self-Cleaning...
Why did my maytag gemini double oven coil caught on fire and break in half?
Because it failed
Ask an appliance parts store how
many times they see that
Jul 18, 2014 | Maytag Gemini 30" Self-Cleaning...
My Maytag Gemini range has a F9-4 code when trying to clean?
Hi There
I have found this code for you and hope this is helpful.Let me know how it goes.
F9 Door latch Check door latch components.Best Regards Richard
Jan 06, 2010 | Maytag Gemini 30" Self-Cleaning...
The Maytag Gemini is didplaying an f9-3 code, what does this mean?
somthing wrong with upper door lock, bent, door misaligned, problem with lock itself
Dec 25, 2009 | Maytag Gemini 30" Self-Cleaning...
Maytag MER6772 Gemini Electric Kitchen Range Logo
87 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
