Question about Frigidaire FPET3085KF Professional 30" Double Electric Wall Oven
Frigidaire Professional FPET3085KFB Double Wall Oven The top oven does not heat well, tried pre-heating to 450 and it only makes it to 225 after an hour. The bottom oven works fine. I have already replaced the temperature prob.
4 Suggested Answers
  • 20 Answers
SOURCE: Element in top oven not heating up all the way.
Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
Posted on May 29, 2009
heatman101
  • 43501 Answers
SOURCE: Double Oven Bottom oven will heat in Bake mode but will broil
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 26, 2010
heatman101
  • 43501 Answers
SOURCE: frigidaire pleb30t9fcc double oven -- top oven
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
heatman101
Posted on May 18, 2010
Early 1960's Frigidaire 24" Double wall oven not heating
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
Nov 07, 2014 | Ovens
Used the self cleaning option and now top oven will not heat?
Good Morning Friend,
I understand you used the self-clean option on your Frigidaire oven, model# FPET2785KF, and now the top oven will not heat. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "set clock" button, entering in the time, then pressing the "start" button. Set the upper oven for any cycle at any temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your wall-oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Professional 27 In. Stainless...
Why when i used the self cleaning option on my upper oven will it not heat anymore?
Good Morning James,
-Best Regards-
WP
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
Pleb30t8ccb
Good Afternoon Friend,
I see that your Frigidaire double oven, model# PLEB30T8CCB, is having trouble with the top oven not heating.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on to heat up, and if it does not, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 09, 2012 | Frigidaire 30 in. Electric Gallery Series...
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
May 29, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire FPET3085KF Professional 30" Double Electric Wall Oven Logo
112 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
