Question about Coldtech J4SRR-40B Commercial Refrigerator
Need circuit board to control temp. It is jrsrr-10b
    Habit-Forming:
  • 76 Answers
L is no longer available, the only thing you can do is re-wire the control section to use a simple thermostat and timer to control the condenser and leave the old controls for a thermometer only.
Posted on Mar 22, 2014
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Why won't blower shut down after gas cycles off?
The circuit board should control the blower and on that board there are very small relays that may be sticking closed. Board may need to be replaced. Also, most furnaces have high temp safeties. When the safety opens, the circuit board thinks there us a high temp problem, them brings blower on to cool it down. These safeties are normally wires in series with each other and possibly with other components. It also could be a shorted control wire or t-stat allowing "r" to "g" connection
Nov 15, 2015 | Heating & Cooling
After turning off the unit the display is off but the unit is still running.
If it has humidity control and the cool is still on but set temp is higher than the room temp, the humidity control will override set temp. If it has no %rh control then it probably has a circuit board fault; micro relay is stuck closed and board needs to be replaced. Its probably the circuit board. On it, there is a little black box(s). About 1" X 1/2" in size. With long run times the small contacts inside will fuse/melt together.
Jun 20, 2015 | LG Electronic Window Air Conditioner
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
Display has gone back, can"t
Check circuit board of indoor unit. There must be some open circuit from your printed circuit board.
Sep 11, 2011 | Heating & Cooling
Model JGBP28DED1WH Stove heats up then temp. drops off ,have to shut off and restart stove.I have replaced ingither in stove,control circuit board,whats left to replace.???
This problem is most commonly caused by a weak ingitor, but as you stated that you have already replaced that, the next most likely cause would be the oven temp sensor, part # WB21X5301 . The control circuit board is very rarely the cause of such a problem.
Feb 28, 2011 | GE Kitchen Ranges
I have a whirlpool side by side refrigerator model no GS5SHAXNB00 refrigerator light blew this morning i replaced the bulb no lights working on refrigerator side and temp control settings
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Mar 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Danbysilhoutte
sounds like you need to replace the control board, i believe there may be two parts here - if there are, try replacing the power control board before trying the electronic control piece... this is the board that has the low and high voltage circuits and relays.
May 18, 2008 | Danby DWC283BLS Wine Cooler
Coldtech J4SRR-40B Commercial Refrigerator Logo
78 people viewed this question
Top Coldtech Refrigerators Experts
Dan Webster
Dan Webster
Randy Justice
billconfused
Are you a Coldtech Refrigerator Expert? Answer questions, earn points and help others
