Question about GE JTP45 Electric Double Oven
We have a GE electric oven JTP 45 and the cooling fan goes on for hours after we use the oven which is really loud and annoying..any tips or solution to his issue? thanks
Master_Tech
  • 770 Answers
SOURCE: Fan runs for hours after use
The fan is in place to cool the electronics it will run after the unit is off it is possible you have a bad sensor on the fan circuit leaving it to run too long
Posted on Apr 05, 2008
vortash
  • 431 Answers
SOURCE: COOLING FAN DOES NOT STOP AFTER HOURS
Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
Posted on Jun 15, 2009
  • 3230 Answers
SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck,
Posted on Jun 28, 2009
  • 69 Answers
SOURCE: My GE Oven JTP 14 displays an F9 error and shuts
call GE they are real helpfull
Posted on Sep 02, 2009
heatman101
  • 43501 Answers
SOURCE: GE Oven door won't unlock after cleaning cycle (and cool down).
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 26, 2010
Ge jtp 20 oven glass exploded, how to replace
most oven brands say it cant be replace in the field , never had to replace it give me more info and i will look for one for you , make, model serial number , thanks
Dec 02, 2011 | GE JTP20 Electric Single Oven
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
My GE Oven JTP 14 displays an F9 error and shuts off.
F9 error - Lock switch error.
Resolution - Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Hope i helped you.
Thanks.
Sep 02, 2009 | GE Profile JTP18 Electric Single Oven
Jun 15, 2009 | GE Profile JT912 Electric Single Oven
When oven heats up the fan gets really loud and doesn't turn off for a long time
if your oven is fairly old, dust might be the enemy. FIRTS Turn off the breaker on your house electrical panel that feeds power to the oven before doing anything. Do not electrocute yourself!!
Remove the control console bezel where the control panel for your oven is..it's probably held on by a few screws. You'll see the fan is there somewhere inside the enclosre, it's purpose is to keep the circuit board cool but the fan grill is probably clogged with dust...remove the fan from the enclosure...try using a vacuum to get the dust out...you might need to use a small brush to loosen the dust film, clean the fan blades while you're at it. Reassemble and turn on the power ...you'll probably find the fan runs much quiter...good luck
Jun 08, 2009 | GE JTP15 Electric Single Oven
Is it easy to replace the lower element on a jtp 15 GE oven? While the wife was baking last week, the lowere element burned out. Was wondering if I could replace it myself
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Mar 23, 2009 | GE JTP15 Electric Single Oven
JTP15 GE Oven - vibration noise
We have a double ge wall oven. The vent fans had become really loud. I checked the price for new fans...$275 each! Plus service of $200. If your oven is not too old, go to GE service purchase a 1 year service contract for $93.00. Wait one one month till it takes effect. Call them and request service and the entire replacement is free.
Jan 14, 2009 | GE JTP15 Electric Single Oven
GE JTP45 Electric Double Oven Logo
57 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
