Question about Canon EOS-10D Digital Camera
When i power off it shows it is still turned on
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 116 Answers
First, make sure that you downloaded any photos so that you don't lose them. Next, open the battery cover and remove the battery. Count to twenty, then put the battery back. Try switching on and off and see if that cures the problem. If not, remove the battery again and look to see whether there is a secondary lithium watch size battery in the battery compartment. If so try removing and replacing it. Then put the main battery back and try switching the camera on and off. Then remove the memory card and try switching it on and off. Then, if it still won't shut off, try going through the menus and reset the camera to factory/default settings.
Posted on Oct 21, 2013
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
Samsung tv off after few seconds
there is a power regulating ic (5v,8v,3.3v) you have to replace that ic new &check
Feb 01, 2012 | Samsung SlimFit TX-S3082WH 30" TV
Laptop screen is not showing anything after power is on
if the power is on and the screen does not show up , try to hook an external monitor using the VGA cable. If the screen does show up, it means that the problem is in the laptop LCD monitor itself. Otherwise if the external monitor does not show up, that means your laptop does not boot anymore to the operating system. Try to turn off the power and remove the power cable and battery on the laptop. Then press and hold the power button for 8 secs. Then reinsert the battery and power cables on the laptop then turn on the laptop. If there is still no screen displayed then call Lenovo for repair of your laptop.
Oct 22, 2010 | Lenovo 3000 C200 Notebook
Cash register will not open, it shows e-94 on the display. We have a PCR 260 B when I insert th key and turn the register on e-94 shows on the display.
This shows a paper jam OR printer problem.
-Remove jammed paper.
-Turn Mode switch to OFF then turn to ON, or Turn power OFF then turn power on.
This could also be caused by wear or a broken or cracked gear inside the printer.
Unfortunately this model does not allow you to disable the printer and run solely from the register.
Regards..
Jul 26, 2010 | Casio Parts Cash Register PC Desktop
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Camera will not show picture
clean the battery with alcohal and *** juices
Sep 21, 2008 | Sony Cybershot S650 Digital Camera
POWER OFF alert
When you turn on receiver it will power off. Poweroff shows up and than turns off. if the front panal reads over load the output ic pac001a is defective i had repaired this model before
May 29, 2007 | Pioneer VSX-D710S Receiver
Canon EOS-10D Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
