Question about Music
Fuse size in marshall valvestate vs100
4 Suggested Answers
  • 5 Answers
SOURCE: marshall valvestate 8080 1. when i turn the buttons they make a cracking sound 2.when i play on it the sound becomes very quiet
As an electronics tech for 40 years I have spent half of those years reparing the damage done to electronic equipment by WD40. It is a great product when used in the correct situation. When it comes to cleaning controls in amplifiers etc the correct procedure is to apply a contact cleaner to flush out any dirt then apply a contact lubricant. WD40 contains minute graphite particles as well as corrosive chemicals. Between the two they swiftly render the controls to the bin.
WD40 great for unlocking rusty screws etc but never use it in electronic gear.
Posted on Jun 01, 2010
  • 17 Answers
SOURCE: its a marshal 8080 valvestate 80 v and it buzzes
Buzzing could be normal for this amp, especially if you have the gain cranked way up (or the volume way up) see if the buzz goes away when you turn the gain/volume down. If not, there is a problem that needs to be properly diagnosed by the amp tech at your local music store. The crackling is also unfortunately rather normal for an amp that's a little older. Oxidation builds up inside the knobs and makes that noise as you turn them. If it only happens when you change settings I wouldn't worry about it, but if it gets bad, a tech guy can clean it out for you.
Posted on Mar 05, 2011
  • 1212 Answers
SOURCE: marshall valvestate 2000 avt no effects
If just no effects, look for a loose ribbon wire. Check footswitch and make sure the plug and jack are fully mated.
It is possible you have a defective 4558 IC, about the only way to locate the problem IC or transistor quickly is to "buzz test" the circuit. You may need to have an audio input of some sort pugged in as well to get the effects to respond. Expose the bottom of the chassis, and with a screwdriver begining at the output, work your way back through the stages/ICs until you lose the signal. Since you seem to indicate it is at the effects, begiin where they end.
Also make sure the solder connections are sound.
Pin 3 and pin 5 are the positive/noninverting inputs to the 4558 series of IC.
Posted on Jan 27, 2012
Testimonial: "thanks very much...chris"
Marshall repair valvestate 8080
if it is C1 then it's the input capacitor from the instrument jack input, it's value is 10nF, as to it's type it could be 1 of three and I don't know without seeing it although all would work, from cheapest to most expensive, they are :- mylar, polyester or polyester film.
Good luck.
Aug 17, 2014 | Marshall Amplification Music
Marshall troubleshoot
First check the preamp valve in that curcuit
Feb 26, 2014 | Marshall Amplification Music
When I plug my P803 2 Way footswitch into my Haze40 amp the effects light flashes and the footswitch will not change channels or effects.
The P803 is designed to work with the "Valvestate" and Tube amps. I don't think it is compatible with the Haze40 since they have an optional 4 button footswitch so the optional one would necessitate different interface than the P803.
Jun 02, 2011 | Marshall Amplification Marshall P803 2-Way...
What is the fuse rating for a Marshall MG30dfx?
According to the schematic, the fuse for 120 volt is a 1 amp.
This is a reasonable size for this size amp.
May 13, 2010 | Marshall Music
My marshall valvestate 100 will completly cut out when im playing and the only way to make it come back is to turn it off and then on. it makes a really loud pop when i have 2 preform this task
It sounds like one of the filter capacitors is getting ready to fail in the power supply. Here is a link to some good info:http://www.geofex.com/ampdbug/ampdebug.htm Here is the schematic:http://www.ampix.org/displayimage.php?album=31&pos=112 Let me know if this helps.
Nov 30, 2009 | Music
Hi, I have a Marshall 8240. The Reverb output
probably the reverb tank These coils are very thin and tent to break easily
Nov 05, 2009 | Marshall Amplification Marshall MG250DFX...
Marshall valvestate 8080 1. when i turn the buttons they make a cracking sound 2.when i play on it the sound becomes very quiet
When turning the knobs you might get a crackling noise if the amp is old, The knobs get worn. Either you can replace them or repair them with a tiny squirt of WD40. Check youtube videos for help.
As for the fading sound, That would be your valves ... They need to be replaced ... I suggest taking it to a repair dhop for that because they need to be matched.
May 22, 2009 | Marshall Music
Music Logo
60 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
