Question about Cameras
My taco will no longer take photos. I have replaced the batteries two times. I'm not getting anything back from my red PIR indicator??
  • AGeralds
    AGeralds Oct 21, 2013
    Its called autocorrect! You obviously dont know the answer or you would have figured out what I was talking about. Let me guess your answer would be, I need to buy a new one!
    Problem Solver:
  • 6 Answers
TACO's are not cameras
Posted on Oct 21, 2013
Testimonial: "Its called auto-correct! You obviously don't know the answer or you would have figured out what I was talking about. Let me guess your answer would be, I need to buy a new one!"
I can't get my Shimano Di2 battery to charge. Do I need to replace it? I purchased the bike in 2012 and have never had this problem until now.
Rechargeable batteries have a finite number of recharge cycles. If yours will no longer fully charge, including after you run it all the way down. then it needs to be replaced, assuming your charger is working properly.
May 26, 2017 | Shimano Cycling
Why isn't it working?
Replacement batteries could be no good or installed incorrectly. Could be just good enough to get the time display working but too weak for anything else
Jul 21, 2015 | Televison & Video
My taco red robin is leaking water can I replace the seal?
Yes you can if you get the casting number I can find them for you
Jan 08, 2015 | Taco Pumps Taco Red Baron In-line...
PIR switches and house wiring is incompatable?
Several possibilities. First use standard light bulbs until it is working. Some of the PIR have triac outputs which need a minimum amount of current to work. CFL and LED lights can be a problem with electronic switches/dimmers.
The PIR needs electricity to operate. The black and white wire are probably power and return, there is no neutral to connect to the PIR. Unless you can get a different PIR that does not need line power to operate you are out of luck. There may be some that can cycle steal power and would work but I am not familiar with them.
I assume the three way is a three way PIR and the lights that are flickering are electronic such as LED or CFL.
If you talk to one of the people where you bought the switch they may help you free of charge.
Good Luck
Feb 23, 2014 | Electrical Supplies
PIR MODE SET UP
I use mine set up for motion sensitvity..this means something must enter the units field of view to be photographed..I set it for maximum distance and to take a photo every couple of minutes..I use an sd card thats 2mb yours may use a 4 6 or 8..look into the window display and see how many photos it will take..mine will do 3000 on the 2mb card..make sure the card is unlocked before putting it in the camera..and you have new batteries in it..
Jan 15, 2014 | WGI INNOVATIONS Video Cameras
My Beocom 6000 table base unit no longer charges
If your base has a charge indicator on it and it indicates that the handset is charging when the handset is in the cradle, I would say you need a new battery. RadioShack sells a replacement battery for $22.00 at the following link
http://www.radioshack.com/product/index.jsp?productId=2815547&CAWELAID=107599274
If the charge indicator doesn't come on it is unlikely that it is the battery. You may be able to get the phone repaired by the manufacturer but it may be better and more practical to get a new phone.
Jan 07, 2010 | Lands Phones
Battery light 4 times is red and one time green in all the time
the battery LED is indicating an internal battery failure. While the battery may still work, the LED indication will not change until you replace the failing battery. It can be an indication of a Failed Cell, low voltage etc. Something in the battery is no longer meeting specification and that triggers the LED indication.
ONLY RESOLVE, NEW BATTERY
Apr 11, 2009 | Dell Latitude D610 Notebook
Power problem
Seeing as you notice that your battery life is half, this most likely means your battery is no longer able to hold a charge, or a full charge. It could also mean the battery is defective.
If your laptop is still under warranty, the manufacturer may replace it. If not, you'll have to buy a new battery, unless you always keep it plugged in anyways.
Mar 23, 2009 | Dell Inspiron 600M Notebook
Monitor is blank
Is there an internal battery that might need to be replaced?
Sep 14, 2005 | Nikon D2H Set Digital Camera
Monitor is blank
Sep 14, 2005 | Nikon D2Hs Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
