Question about Lenovo IdeaPad Tablet K1
Stuck in reboot mode - Lenovo IdeaPad Tablet K1
Why is it stuck on the reboot screen?
reset it somewhere to push a few buttons together by reboot or start this will maybe the tablet goes booting in a bios factory mode with Chinese symbols like a Polaroid smartphone.
Mar 06, 2016 | Ematic 7" Touch Screen Tablet
Why is it stuck in reboot mode?
You've either got a faulty update or some system errors.
Do a factory restore as soon as you take your stuff off it.
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Feb 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Kindle, stuck in sleep mode
How to Reset Kindle - courtesy Andrei Pushkin
Kindle DX, Kindle 2 or Kindle 3: This is easy - just hold the power button (next to the headphone jack) for 15 seconds and the device will reboot.
Reset Kindle 1: This is trickier as you'll first have to remove the back cover; you'll also need a paperclip.
Read more: Reset Kindle
Jan 29, 2014 | Amazon Kindle Wireless Reading Device
Kindle hd stuck on reboot
Try a hard reboot:
To reset/reboot your Kindle Fire:
-With the Fire charged but unplugged from the charger, press and hold the power button for a full 20 seconds.
-When the Fire cycles off completely, press the power button once to turn it back on.
Nov 22, 2013 | Tablets & eReaders
Reset manual for royqueen tablet pc
1. Press the power button to get the option menu for
Power / Reboot / Silence option.
2. From that menu you'll have to hold down the Power button while holding down the Home button on the side of your tablet.
3. This brings up a menu to "Reboot Into Safe Mode" (These first 3 steps the manufacture fails to mention, which is where many users get stuck)
4. Hit yes for Safe Mode and then hold down both Power and Home buttons on side till the Dopo logo appears.
5. Release the buttons and hit the Power button one more time, then hold the Home button down till a menu option appears.
6. Use the Home button to move down to "Factory Reset" and press the Power button to select that option. Once it says "complete" then use the Power button to select "Reboot."
Jul 22, 2013 | Tablets & eReaders
My android tablet is stuck on android screen
Try Clearing the Cache by rebooting the device in Safe/Recovery Mode.
May 25, 2013 | Archos 7 Home Tablet Tablet Android 8 GB 7...
Need to unlock my craig 741e tablet
I got a Craig 741e (CMP741e), FCC ID AQF-RA-WN11087A with a lost password, stuck on a lock screen, forgotten pattern, no wifi connectivity.
The Craig does NOT support a reset mode, none of the typical combinations of power/volume buttons get you to a restore screen.
The only supported way to restore to default is a firmware restore mode.http://www.craigelectronics.com/site/pdetails.php?id=414 will tell you how to get the firmware file
http://www.craigelectronics.com/firm...irmware4.0.rar
(install instructions: http://www.craigelectronics.com/firm...guide_741e.doc)
HOWEVER! Some CMP741 units will end up stuck on the green Android screen with this version!
If that happens, Craig has supplied a cleaner firmware in case that the first one fails,
http://www.craigelectronics.com/firm....0_cleaner.rar
The name of the core image in that RAR file is sun4i_crane_aihua_20121121, if that gives anyone clues about the system.
Installs the same way - will reboot several times after the firmware install completes, and will fail the first time it runs ("Unfortunately, <process name> has stopped." over and over again). One more reboot will solve that issue.
The Flashing software, PhoenixCard 3.06, is VERY buggy. If would not work with my built multi-card reader on my PC or with an add on-SD card reader on that PC. (could not even see the card). On my laptop, the built in PCI Card reader never recognized the card, but it finally burned the card using the add on card reader. Some people suggest disconnecting ALL USB peripherals before burning. Also, I found if the flash burning failed over and over, sometime a reboot caused PhoenixCard to start working again.
Dec 31, 2012 | Tablets & eReaders
Lenovo IdeaPad Tablet K1 Logo
Top Lenovo Tablets & eReaders Experts
vojvodabudva
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
