Question about Ludwig LE2482R Percussion Learning Center Combo Kit
Ludwig LE2482R Percussion Learning Center Combo Kit How do I put the bells on the stand
Tuning
I'm sure its tuned like a drum, use the lugs. As for the stand, a standard cymbal stand should work.
Jun 28, 2012 | Ludwig 8" Tunable Practice Pad
Just moved houses, and the amp puts out loud static when cable is plugged in. The house may not have grounded plugs, and I do not see a separate ground screw for attaching a stand-alone ground wire. What...
get a 3 way adapter,, plug your amp into the adapter, and secure the ground wire to the center screw in the receptical cover , or if it comes with a tab instead of a wire, secure that
May 30, 2011 | Fender Frontman 15r Combo Guitar Amplifier
My ludwig L315FP bass drum pedal keeps bouncing and i have loosened the spring all of the way. I still cannot get it from multi hitting the bass drum. Help?
Go to YouTube and search for "Bass pedal" There are many videos. Select and view ones on "setup" and also view "technique". These will solve the problems you are having.
Apr 02, 2011 | Ludwig L315fp Accent Custom Single Bass...
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
Mar 09, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
Yamaha dtxpress iv standard
try a wooden snare, a light kick drum, the most natural hi hat you can find, some soft cymbals and a selection of wooden and metal percussion instruments.
Dec 25, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Ludwig LE2482R Percussion Learning Center Combo Kit Logo
23 people viewed this question
Top Ludwig Music Experts
Vito Vacirca Jr.
Are you a Ludwig Music Expert? Answer questions, earn points and help others
