Question about Thermador Ovens
Oven stopped working. Giving blinking lights code of 55 on thermador pd48.
    Sergeant:
  • 401 Answers
Hopefully you have a manual or you bought it from Lowe's, in which case your problem might have a possible solution.
Posted on Oct 21, 2013
4 Suggested Answers
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
fixyourboard
  • 310 Answers
SOURCE: thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Jun 19, 2010
taran_2005
  • 10515 Answers
SOURCE: code f34 for my thermador
According to a Thermador error code book for a single Thermador oven. It says its a air flow problem. This means it could be the fan motor sensor telling the control board that it is not spinning fast or not at all. or it could be a micro paddle switch that is activated by air flow. Recap : if your fan blower motor has 4 wires going to it, it has a sensor reading the rotation of the motor.... if yours does not have this then you should look for a paddle switch.This could also be a result of fan may be too dirty to operate correctly. Try to clean the oven. If you had this error after electrical surge or outage recently, then turn off the dedicated circuit @ circuit breaker box for about 1 Hour and hopefully it would resolve the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 24, 2010
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
How do I stop my Thermador Oven SC302TS from beeping F7
Check this link for possible solution. It says that a function key may be stuck or you may have a problem with a control board.
Thermador Fault Codes AppliancePartsPros com
Feb 24, 2015 | Thermador SC302T Electric Double Oven
Thermador oven preheat light comes back on during baking session. Oven doesn't stay hot enough to finish cooking food.
Get it repaired from authorised personal. Seems sensor elements has gone down or programming chip is malfuctioning.
Oct 05, 2014 | Thermador Ovens
Thermador oven preheat light will come back on during cooking session. The clock has also stopped working.
There may be a fault with the control board.
http://appliancejunk.com/forums/index.php?action=dlattach;topic=9146.0;attach=5091
Thermador oven will not self clean.The blower fan does not turn on, and the word HEAT never appears when LOCK stops blinking. In other words, after following steps 1,2 and 3 fan and heat never happens.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 23, 2010 | Thermador Ovens
Hgc5-1 hobart gas convection oven board giving a 3 blink code after flame shuts off what is the code error seems like maybe a limit
Test wire nuts on wire #54 and #55 (on 550 degree high limit switch) for continuity, should show shorted if shows open, limit switch is bad. Test by jumping if oven works switch is bad.
Sep 01, 2010 | Ovens
Thermador oven control panel light is not working
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Fisher&Pakel Oven os301
re-boot, I shut the breaker down for a few seconds and bingo, problem fixed
Aug 07, 2007 | Fisher and Paykel OS302SS, Stainless Steel...
Ovens Logo
129 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
