Question about Klimaire Heating & Cooling
Fan will only blow on low when heat is on - Klimaire Heating & Cooling
  • 24 Answers
Your fan most likely is wired for low speed for heat which is common. this should be determined when furnace is set up properly. motors that aren't modulating motors and are multispeed motors typically have low medium and high taps that come off the motor and go to the corresponding relay on the board. low and medium speeds are used for heat and high and medium speeds are used for cooling. but only one speed for heat and one speed for cooling many times medium never gets used. im not familiar with klimaire is this a mini split system and not a regular air handler. cause speed control should be adjustable from the remote. if its a split but if not reaching desired speed due to a malfunction in the units could cause it to run low speed just to maintain the temperature exiting the indoor unit.
Posted on Oct 21, 2013
I have a 2005Chrysler minivan front heat does not blow back heat blows cold cold air front doesn't blow at all what could this be
If the front heater does not blow any air suspect a defective fan motor or resistor. You can try turning the blower on and banging the underside of the passenger dash to see if it begins working again. If it does, suspect a bad fan motor. If blowing only cold air, the most common problem is a low coolant level
Jan 05, 2016 | Cars & Trucks
No heat
Leak in radiator and/or hose. Hot water from radiator flows through heater core and fan blows heat inside car. Too low coolant level and there's no heat!
Nov 28, 2013 | Cars & Trucks
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Only blowing air when i program for heat
Generallyif gas, the heat speed is low and routed through a normally closed switch in the fan relay, the fan relay has another inverseley proportional switch to the normallyclosed m a normally open one that sends power to high speed for AC or fan on position rather than fan auto. In auto the normally closed has power passed through to a temperature or time delay, that controls the heat or low speed.
Apr 07, 2010 | Honeywell Programmable Thermostat Heater
Fan works but it blows low heat
there is a cab air filter located under your hood, pass. side under the wiper area, but this should not be the problem if your loosing coolant, check your heater core, if your fan only works on low. check your blower resistor you can pick em up new for around 20 bucks. hope this helps and god bless.
Feb 09, 2010 | 2000 Ford F250 Super Duty Crew Cabs
HEATER NOT WORKING IN 2001 LEXUS RX 300
you most likely have a bad airmix servo. this happens alot on these. they are expensive to replace too.
Sep 10, 2009 | 2001 Lexus RX 300
This is a heating and cooling through the wall heat pump. It works normally when heating is selected - the heat pump runs and both speeds of the fan blow warm air. But nothing runs when cooling is...
You have a bad board or bad switch. I would say board. You can have service tech check this out. There is only so far you can go without knowledge of Controls ad electricity. Russ
Jul 21, 2009 | Heating & Cooling
Heater fan blows intermitent even if not switched on
Replace the blower fan resistor located under passenger side of dash near center console. Updated part has larger heat sink to repair previous problem.
Mar 29, 2009 | 2000 BMW 5 Series
Car heat blower is not blowing heat/air into the care
it's either a fuse or it's a bad blower motor, it could be a bad blower motor resistor but usually you'll get either high or low only, so if you have nothing on any speed, high low etc, and all the fuses are ok chances are it's your blower motor.
Jan 16, 2009 | 1999 Audi A4
Low heat
if this is a heat pump it should either be low on freon or problem with airflow over outdoorcoil. (like a fan that failed or really dirty coil) PLEASE keep in mind if this is your first year with a heatpump instead of a furnace it does blow air out MUCH colder than a gas furnace or boiler.
Thanks ,
Brian
Nov 24, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
165 people viewed this question
Top Klimaire Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Klimaire Heating and Cooling Expert? Answer questions, earn points and help others
