Question about kawasaki Krb750b Backpack Leaf Blower
Blower runs for about 10mintues than starts dropping power and starts going up and down in power asw if its going to shut off.
    Sergeant:
  • 401 Answers
Sounds like you need to turn off the choke.
Posted on Oct 21, 2013
Rudd silhouette ii blower
Send direct power to the blower by bypassing relay . See if motor runs
Jul 19, 2017 | Ruud UBHC Air Conditioner
My furnace heats up and then shuts down not kicking on blower
Your furnace is shutting off on the high limit switch because of this. You are having a problem with the blower motor. You need to check for power from the wires on the board that feeds the motor. If you have voltage, and your run capacitor is good, you have a faulty blower motor. If its a fan relay, the fan would start and run all of the time. Check power to motor right after furnace shuts the burners off.
Robert Horton
Nov 05, 2011 | Intertherm P3RA-048K Air Conditioner
I have a gas craftsman leaf blower/vac 32cc. it starts ok but it wont shut off. what can I try?
Hi, W/D here.
There should be a switch at the front of the machine that you can depress to break the power and shut the machine down. Most of these type switches will go to off only as long as you hold the switch down, then return to the run position when you let off of it. Take a closer look, and you should see it.
Best regards, --W/D--
Apr 07, 2011 | Craftsman Garden
My Taylor 745-27 starts hopper comp. comes on, blower starts,beatersrun,fan shuts down beaters stop compressers sun for a shoet time then shut down, the beeps and starts the process over again Any...
could be a dirty condenser. Hi pressure safety is preventing a dangerous condtion by shutting it down. When pressure drops, unit cycles back on. Check it out.
Jan 12, 2010 | Freezers
Fuel leak after I shut off the blower and set it down.
Well, if gas is running through your engine and out the muffler, there's a lot of fuel inside the crankcase and I doubt that you would be able to start it. My thought is that there is a cracked fuel line or fuel tank, with emphasis on the fuel line. You may want to take some housing parts off to see if you can see a drop of fuel hanging on the fuel line where it may be dripping and running over to the muffler area.
Oct 31, 2009 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Ruud silhouette #UHDG-07EAUER won't heat house
Cleaning the flame sensor has nothing to do with blower motor not turning on. You either one of the following problems 1 bad cap for motor. 2 bad motor. 3 bad limit on blower housing or 4 a bad board. You will need a volt meter to check for these problems. Try seeing if the fans runs with unit of and fan switch turned to on. Also does motor hummmm. Is motor cage free ( can check by manually turning) If motor doesnt humm and the cage is free wheeling then you will need to find out if you have power going to the motor. If you find out that you do then you will need to change blower motor. If you do not have power then you will need to check limit with continuity tester on volt meter. If that checks fine only 1 thing can be wrong and that is the board.
Feb 14, 2009 | Ruud UBHC Air Conditioner
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
kawasaki Krb750b Backpack Leaf Blower Logo
64 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
