Question about Technics SA-EX140 Receiver
Can you have both a and b speakers on at same time?
Why can I only select one set of speakers at a time ?
Press the speaker buttons you require at the same time! Not one at a time.
So if you want A & B then press both buttons together.
Aug 01, 2016 | Pioneer SX-1250 speaker selector switches...
It`s showing overload
There are a number of causes....but most of the time something in he speaker section is shorted. Turn off the stereo...Remove all connected speakers from the back...turn it back on. Is the error message still there? If so its internal...if not turn off again and attach one speaker at a time, turning the stereo off to add each speaker. until error. You could have a shorted speaker or wire or too many speakers.
May 11, 2016 | Audio Players & Recorders
It seems that my logitech LS11 have not been working, my head phones work but when i plug in the speakers they dont seem to work
i assume that you have had these speakers a couple months now. by this time the design already starts messing up .... buzzing speakers, not working, as you can tell from this sight no one is happy with these speakers. http://reviews.logitech.com/7061/4252/logitech-ls11-speakers-reviews/reviews.htm by this time most people pretty much garbage it anyway.
Jul 01, 2011 | Logitech LS11 Speaker 2 Speakers
Have outdoor speakers but will not play sound, they are connected to a xantech pa1235x and the indoor speakers work but not the outside ones
Check the reciever and verify if you have a selector swicth pressed for A speakers and B speakers and see if this helps...
Some recievers will only power A or B, not both at the same time.
Lets not assume your outdoor speakers work. Would be helpful to know if you have tried to disconnect the inside set and plugged the outside speakers in those stereo jacks. If no sound, your speakers may have loose wires on the inside of the box/cabinet/case or they could be no good period.
If they do work, and the system does not provide all four jacks to be powered at the same time. You may consider buying a pair of piggy back rca jacks. Plug in the indoor and outdoor speakers into the same connectors the indoor ones are on now.
That way at least you can run them all at the same time from the speaker connector where you have the indoor speakers hooked up..
Hopefully you'll find something useful in this
Good Luck
Respectfully
Jun 09, 2011 | JBL N24AWIIBLK Speaker
Aiwa receiver won't turn on
Hello:
This looks like its displaying the Time format. Try disconnecting all speaker one a time and turning on the unit to see if it turns off. Disconnect one speaker at a time and turn the unit on. If it turns off with only one speaker conn then this speaker is your problem. Amps will shut down if a speaker goes bad. Another thing to try is disconnecting all inputs and speakers from the unit and see if it stays on. Then reconnect them one at a time while watching what the unit does during power up. Also you might want to open the device and check for blown fuses. Check for any speaker terminal wires touching each other if so it will shut down thinking there is a short.
Nov 30, 2009 | Aiwa AV-D50 Receiver
Everything works the speakers are hooked up i just
connect one speaker at a time .If one speaker or speaker wire is bad it will cause all audio to mute.connect one speaker at a time
Jul 30, 2009 | Pioneer DEH-P3500 CD Player
Speaker Wiring Troubles
A loose connection with your speaker wire... This does tend to happen time to time. Just reconnect the speaker wire.
Mar 31, 2009 | Pioneer TS-A6962R Car Speaker
I have an nokia n78 and my right speaker isnt working
hallo i have N78 its right speaker not work now its dont work at that time when i play song at that time i masg i reseve that at that time right speaker not works plzzzzzzzzzzzzzzz answer me
Feb 19, 2009 | Nokia N78 Smartphone
LS & RS Speakers Aren't Working?
if the sattelite speaker drops several times. i thing the filter of the speker are broken or the magnet of the speaker are separated from its coil. thats why they dont work... that mean you must replace a new sattelite speaker
Feb 18, 2009 | Cyber Acoustics CA-3000 Computer Speakers
Technics SA-EX140 Receiver Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
