Question about LG Washing Machines
Message of OE coming up on my LG WTH756 Washing machine,it also has a funny burning smell and machine not draining. Please help!!
MNTECH
  • 1543 Answers
SOURCE: lg wm2277hw
You do not have an "OE" error, you have a "DE" error. DE error is "drain error" which displays if the washer has not pumped out after 10 minutes. If there is water in the machine and no obstruction in the filter I would suspect that the pump impeller is bad, and you would need a new pump motor. (part # 4681EA2001D) Pump motor is located directly to the left of the filter, and can be accessed by tilting the washer back and reaching it from underneath. The pump housing is held onto the machine by three phillips head screws.
If you have "DE" error and there is no water in the machine that's a whole different problem I'll address if you say that's the case.
If you need good service, try calling a small dealer who sells and services the procuct line you are having a problem with. You can find LG servicers at us.lgservice.com but avoid the utility companies, A & E, Sears, and all the big guys who try to service every brand but often times are not very familiar with your brand.
That should help. Carl S., factory authorized LG technician for over 10 years.
Posted on Aug 26, 2008
SOURCE: tromm washing machine, front load from LG
I am getting an OE message during the washing cycle in my LG Tromm washing machine. What does it mean and how can i fix the problem?
bscavella@sbcglobal.net
Posted on Feb 17, 2009
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Posted on May 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: LG WM2277 "OE" ERROR. PLEASE HELP
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Posted on Sep 15, 2010
Our lg washing machine has an OE error message what does this mean
Hi dear.OE code related to drain problem.Please checked the filter,open it,clean it & check for any obstacle blocking the pump to do it's function.(Impeller of pump should freely turn.)Please also check drain hose for kink & blockage.Please keep in mind,some times pump seems normal but it can malfuntion & needs to be replaced.If you are not sure,please call service centre.I hope that helps.Thanks.
Nov 12, 2010 | LG Washing Machines
My LG is 5 years old and cannot complete a cycle error message OE. Can't find my handbook help please.
Hello
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Nov 08, 2010 | LG Washing Machines
The washer isn't draining and spinning. Washer has message coming up- OE and it stops working. We were thinking it was the water pump? Please help.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 12, 2010 | LG WM1812C Front Load Washer
Oe message doesn't spin
This LG technicians service manual will help you access the drain pump for service and possibly the door switch for repair.
http://136.166.4.200/contents/Laundry/WM1815/WM1815_Service_Manual.pdf
Jul 17, 2010 | LG WM0642H Front Load
OE error
Jul 09, 2010 | LG WM2233H Front Load Stacked Washer /...
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
Water doesn't drain
water discharge drain $50 part, easy installation. google the lg model to locate part.
Nov 19, 2008 | LG WM-3677HW Front Load Washer / Dryer
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
