Question about Maytag Neptune Washing Machines
One of the baffles is part way off and eating up clothes, but I can't seem to reattach it and am afraid to snap it off.
  • 39 Answers
Judy,
It would be better to try and remove the baffle as the machine should still work fine with only two baffles.
It sounds dangerous to be using the machine with a broken baffle. If you cannot remove the baffle safely, please call out a serviceman.
HT GEEK.
Posted on Oct 21, 2013
Fix rattly noise in gas dryer
could be coins in the baffles, sometimes coins make it into your dryer, and they slide under the baffles, remove or open the top of your unit and you will see the screws that hold on each baffle, remove the screws and the baffle will come off inside the dryer with whatever is in there. then re-secure the baffles..
Oct 24, 2015 | Kenmore Dryers
Shop vac is not pumping out water just fills the canister
The question makes perfect sense assuming we are talking about the ShopVacPumpVac. These devices are, essentially, a combination shop vac and sump pump. For those answering the question, you can see literature on these vacuum/sumps here: https://www.shopvac.com/includes/streamPDF.asp?loc=pdf&id=Shop-Vac-Pump-It-Out .
When I have experienced the loss of drainage, I have found a couple obvious problems and solutions.
First, make sure that the garden/discharge hose is not kinked at any point along the line from the vacuum to the outside. If kinked, the line will not drain.
Second, the baffle can become blocked or clogged. Take the following steps to determine if your baffle is clogged and to clear the clog:
1. Turn off and unplug the vacuum.
2. Unclip the two lid clips.
3. Lift the lid of the vacuum. When properly set up, the baffle hangs below the filter housing on an opaque hose about 1 foot in length.
4. Grasp that hose and pull firmly downward. Once removed, I take that hose and the attached baffle to an outside garden hose.
5. Pull the baffle off the opaque hose.
6. Spray water from your garden hose through the opaque hose to make sure it is clear.
7. Spray the baffle clear.
8. Lightly tap the port of the baffle, where the opaque hose has been inserted. Most of my clogs have been the result of hair balls (or worse) at this point. Just tap any blockage out and rinse.
Third, reattach the baffle to the opaque hose. Reattach the opaque hose and baffle to the motor under the filter housing. Set the vacuum top on the canister. Click the locking clamps closed.
If this doesn't result in clearing the clog and allowing it to drain, then you are in the exact spot I am right now. If I figure out this new problem, I will update further. But I have cleared this kind of clog maybe five times in the six months I've been using this new Shop Vac Sump Vac
Sep 08, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Gas runs out all the time gas gauge works when it wants to
Sounds like you have a broken tank or tank connection. The sending unit ( hanger ) has the gas pump and the gauge sender in the one unit htatgoes into the top of thetank. the tank has to be lowered to see. theirs three lines connected with snap on fuel connecters that take a line toolto release them. some methinol fuels will eat the seals out of these and rot the float for the fuel sender. If the tank has been hit hard from the bottom theirs a baffle that can come adrift and run into the hanger breaking the lines as they go though the top of the tank making a leak course you coulda run over something that punctureed and bent the tank.
Nov 17, 2010 | 1999 Pontiac Grand Am GT
2 dryer bars
The bars are called BAFFLES P/N: 12002559
They are attached by 4 screws through the drum. You must pop the top to reinstall the baffles. Take one of the baffles to the hardware store and buy some good fitting screws. Then pop the top 660ff1d.jpgand use a screwdriver to reattach them. Fairly easy to fix. IF you have the old ones. Do dry tennis shoes in there. Oopz LOL
Apr 22, 2010 | Maytag SDG3606A Gas Dryer
Hair/Lint collecting on the Baffles of the dryer
I once heard you can periodically spray "Spray Starch" on the baffles themselves to alleviate lint and hair buildup. If you can prevent the unwanted particles from building up on the baffles theoretically they should be trapped in the dryer's lint collector.
Mar 01, 2010 | Whirlpool Dryers
Two 8182233 plastic baffles broke
This is a common problem on front loaders,Once you get the new baffles they just snap in.They have clips.
Jan 08, 2010 | Kenmore Elite 45986 Front Load Washer
Clothes roll into a ball on kenmore gas dryer #11062202101
Just get the filter out and remove the 2 phillips screw init's housing on top. Then use a putty knife to press against the spring clips that hold down the top Then just roll the drum around to the top where the holes are to reattach the baffle, get some screws and put it back.87656db.jpg
Dec 15, 2008 | Kenmore 63942 Dryer
Kenmore clothes washer top loading
get a big screwdriver and jst pop the out wont break spring steel just reamber haw they hook to the washer and just popem back in when done
Mar 30, 2008 | Washing Machines
Best batteries
Hi, duracell are usually one of the longer lasting ones, but afraid certain wireless devices eat batterties thats the joy of wireless :-( John
Jan 08, 2007 | Labtec Mini Wireless Optical Mouse...
Washing Machines Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
