Question about Reebok Exercise & Fitness
How do do you start over to adjust the belt on a
How do do you start over to adjust the belt on a reebok treadmill?
    Top Expert:
  • Reebok Master
  • 12,223 Answers
See the video attached. and fix it. God bless you
Posted on Oct 21, 2013
  • 16 Answers
SOURCE: Reebok RX100 won't work right
Sounds like you could possibly have a bad drive motor or something is wedged into the walk belt somewhere keeping it from turning. Check this out. One more question. How long does the walk belt turn for, seconds, before it stops. Is it like 3 to 5 seconds or less than that.
Posted on Jun 29, 2009
bwinton
  • 83 Answers
SOURCE: the belt is sticking on my treadmill reebok TR3
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
bwinton
  • 83 Answers
SOURCE: treadmill belt slipping
maxtreadmill
  • 832 Answers
SOURCE: Reebok 8050es treadmill walking belt has started
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
Posted on May 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Posted on May 14, 2010
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Jan 05, 2016 | Reebok Exercise & Fitness
Will a reebok rodger black motor drive belt fit a reebok 2.2edge treadmill
Dear Sir:
Most of the time, can be fit in reebok 22.edge treadmill.Otherwise you can adjust the main motor and puller for to fit.
sincerely. God bless youm
ernesto cuadra
managua, nicaragua. c.a
Feb 17, 2012 | Reebok Exercise & Fitness
When i get on the treadmill the belt stops all of a sudden
Try to tension the tredmill's belt. For that you need an allen wench. Watch the following video to adjust the running belt. All the treadmills uses the same way to adjust the belt.
Oct 10, 2011 | Reebok Vista Treadmill - RBTL13305
My Reebok 9500 ES Treadmill is making a very loud klunking sound from the rear roller - right side. The sound is not constant - it comes and goes. Doesn't seem to matter where I position myself on the...
Treadmill Maintenance How To Lubricate Treadmill Belt
Please lube very well Roller front and back with WD-40
if the problem persist replace Roller(s).
LUBE the deck belt as show in the video.
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 17, 2018 | Reebok Exercise & Fitness
Right side belt tension adjuster is broke. how do
Call Icon Fitness @ 1-800-999-3756
Part# 223406 Cost $7.30
May 19, 2010 | Reebok 8000 C Treadmill
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
May 05, 2010 | Reebok 8050 ES Treadmill
Treadmill belt slipping
Mar 22, 2009 | Reebok Exercise & Fitness
Exercise & Fitness Logo
41 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
