Question about Frigidaire FES367 Electric Kitchen Range
Frigidaire oven won't turn off...Was using it at 300 degrees to slow roast ribs then in about an hour the unit started beeping,flashing F1, on an extremely high temperature, ribs started smoking, fire alarms went off. When we shut off circuit breaker, unplugged and turned back on the oven goes back on high temp. w/o being set. Any advice out there?
    Sergeant:
  • 401 Answers
Make sure that you actually set that as the temp and not the preheat temp.
Posted on Oct 21, 2013
catriver
  • 878 Answers
SOURCE: F1 and constant beeping
Tul2pi, there are several things that could cause this. 1. shorted keypad. If you unplug the keypad ribbon from the board and the beeping stops it's more than likley your problem. 2. Temperature probe in the oven may have gone bad. You would have to ohm this out. At 75 degrees it should read approx. 1091 ohms. 3. Worst of all it would be a control problem itself where as you would have to replace the control board. Since you are so close to the warranty period, I would call Frigidaire at 1800-944-9044 and see if they would cover it...Catriver..post back.
Posted on Aug 29, 2006
catriver
  • 878 Answers
SOURCE: frigidaire code F1
Rainbow, F1 could be one of three things. The loud pop doesn't sound good. 1. Shorted keypad-replace the control. 2. The control sensed a runaway oven temp. In this case you would have to ohm out the temp probe. 3. The control itself may have a shorted relay-replace the control. The temp probe should ohm at approx 1100 ohms at room temp. Unplug the oven for one minute, if the code returns, first ohm the temp sensor (probe) if that checks ok, replace the control..Catriver
Posted on Nov 30, 2007
  • 833 Answers
SOURCE: Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Posted on Dec 13, 2007
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: my frigidaire oven won't turn off but I'm getting no codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Oct 01, 2010
What temp and how long yo cook a 5 1/2 pound prime rib roast
Cook the roast for 15 minutes, then reduce the oven temperature to 325 degrees F. Continue to cook the roast until your meat thermometer reads 110 degrees F. Estimate about 15 minutes of cooking time per pound of prime rib.22 Dec 2014
The world's easiest prime rib roast: Master a holiday classic - Today.com
www.today.com/food/world-s-easiest-prime-rib-roast-master-holiday-classic-t77026 What temp and how long yo cook 5 1 2 pound prime rib roast Google Search
Nov 27, 2016 | Grilling
I want to cook a rib roast in the pressure cooker. How long to cook? This is NOT a pot roast!
Please don't! You will ruin the prime roasting joint in a piece of beef rib. If you want to boil meat in a pressure cooker, use Tri-Tip or Topside. Roast uncovered in the oven for 1 hour and 15 minutes. Rest for 15 minutes, remove from the bones and carve. You can roast the bones with BBQ sauce as a snack another day.
Happy Easter
Andrew - Master chef qualified 1971.
Mar 27, 2016 | Home
At what temperature do you cook bone in and boneless prime rib and how long per pound
13 - 15 minutes per pound @ 300 - 325 degrees F, pull when meat is 125 F - 130 F (internal temp.) for rare to medium-rare. Err on the low side. Allow to rest; the meat will continue to cook while resting. For example, if you cook it to be medium-rare (130ish F), then pull it out of the oven, and let it rest, it will end up being medium to medium-well (140 - 145 F) once cut. So be aware.
Bone-in, bone-out it doesn't really matter, because the bone is not in the center of the meat. It's best to let the prime warm at room temp for a period of time, before cooking. An hour or so from the refrigerator (not frozen).
Some people like to place the prime into a hot (425 F) oven or grill/smoker for 10 -15 minutes, then turn down to roasting temp. This is done to sear the outside, which will give it a crispy/seared outside. This doesn't "lock in" flavor, juices or anything else, it is more of a visual and texture thing. If you do this, the cooking time will be reduced, because the oven/grill will have to come down in temp over a period of time while the meat is cooking. I don't recommend doing this with prime rib. It ends up being overcooked and tough, due to the fast then slow roasting of the meat.
What you want to keep in mind is: roast the meat low and slow. Check the internal temp, with a meat thermometer, early to avoid overcooking. Don't forget the internal temp of the meat will rise after taking it out of the oven. Let it rest for 10 - 15 minutes before slicing the meat.
Mar 26, 2016 | Grilling
I have a frigidaire range/stove. I was roasting dinner at 300 then turn the oven up to 400 near the end. Shortly after there was a pop that sounded like it came from inside the oven. I thought a potato...
F1
  • The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement. If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC). If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven. If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary. If the oven is actually overheating, replace the EOC. If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Read more: Frigidaire Oven Error Codes ' eHow.com http://www.ehow.com/list_7105089_frigidaire-oven-error-codes.html#ixzz1OVfekgRx
Jun 06, 2011 | Frigidaire Ovens
Beeps and flashes F1 while trying to use covection roast
Usually this is a failure in the electronic control. We rebuild a lot of these.
Best Regards,
Bruce
www.fixyourboard.com
Jun 12, 2010 | Jenn-Air SVE47100 Slide-In Electric...
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Convection cooking
Convection ovens are great for roasting!
I cooked a 15 lb  stuffed turkey in 2 hours in mine. And it was juicy and fab!
My auto degree set for convection  is 325.
I have a Jenn Air wall oven, so I don't know, it might be different for different brand.
Roast or bird should be in the middle of the oven. THe air has to circulate well to get best results.
I believe rule of thumb is a convection oven takes 1/2 LESS time than conventional.
Hope this helps.
Jan 13, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire FES367 Electric Kitchen Range Logo
131 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
