Question about Maytag MER5750 Electric Kitchen Range
All burners on my Maytag Performa range model: PER5750QAW stopped working at once. The clock works and the oven works.
    Sergeant:
  • 401 Answers
Maybe something got short-circuited?
Posted on Oct 21, 2013
Noggin
  • 944 Answers
SOURCE: Oven not working properly
Do you mean 200 degrees Celcius or Farenheit? If Farenheit then the most likely culprit would be the thermocouple in the oven which can usually be replaced relatively easily by someone mechanically minded, if Celsius then you should suspect the elements although a working broiler would suggest that there is at least one element that works fine. Maytag says; "Why won't the oven heat up? First, make sure you've properly set all the oven controls. Check your user's guide for more information on your model's controls.(see below for the link to the manual if you need it) If your range offers the option of a delayed oven start, check to see if it's been selected. If so, the oven won't begin to heat until the selected time. If your oven has a lockout feature, check to see if it's been selected. If so, it will prevent you from using the oven. If your oven still won't operate, please contact an authorized Maytag service provider for more assistance." Here is the link to the manual; http://www.maytag.com/assets/product/8113P564-60.PDF and here is the link to Maytag Service if you need it - hopefully not; http://www.maytag.com/support/service_parts.jsp The other possible culprit would be the electrical supply to the oven - it may be adequate for the stovetop or grill but the oven may draw more power than the circuit can handle - even if it was fine before, this can change and may be caused by corrosion, rodents, overloading etc. and may not necessarily trip the breaker switch - if you suspect this at all then get a qualified electrician to check - it shouldn't take long to check so should be cheap, although repairs if necessary may cost more Hope this helps :)
Posted on Jun 22, 2007
jsrock516
  • 5911 Answers
SOURCE: Burners not working on a Maytag Electric Range
The top of the range will open if you remove the three screws under the front edge of the top. You will need to open the oven door to see them. But first, unplug the range or turn of the circuit breaker. There's still live voltages (240VAC) even with the range turned off. Also use care not to lean on the oven door or you could damage the springs. If the top does not have any brackets to hold it up you may need to find something to prop it up, or use a second set of hands. The elements are easily removed by removing a couple of screws and the some wires. Write down the wire colors and where they go to assist in making sure you reconnect them correctly. Also, pay particular attention to the numbered holes on the back of the element. Make sure you reconnect the retaining brackets in the same numbered holes as you removed them. Last of all, do not handle the ceramic material or element coil with your bare hands. They are fragile and the oils from your hands could create hot spots and potentially ruin the element. I do not know the arrangement of your elements, but I suspect you have one of each size burned out. The part numbers are as follows: 6" element: 1032743 9" element: 1035285 The prices are about the same ($40 ea.) with the larger element costing slightly more. I hope this helps you.
Posted on Sep 03, 2007
  • 21 Answers
SOURCE: oven will not work unless range is lit
You probably have a neutral return that is open. By turning on the stove top you are completing the path of return for the bake element. Work back from the element (unplug the oven first!!!) and check continuity back to the plug. Again, make sure you unplug the darn thing from the AC outlet!
Posted on Mar 13, 2009
  • 441 Answers
SOURCE: oven not working Maytag MGR6875ADS
IF THE RANGE IS DOING EVERTHING BUT HEATING THE OVEN IT IS MOST OFTEN THE IGNITOR
Posted on Jul 19, 2009
  • 54 Answers
SOURCE: Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Posted on Apr 27, 2010
Maytag performa range oven top
If there are any screws around or in the burners, they have to be removed first. Once all the screws are removed, use a blade to loosed the burner. Then try turning again.
if you do get it open, lift just an inch or two to make sure you are not stretching any gas lines. They will break then you will need a new stove.
Oct 20, 2013 | Maytag PGR4410 Performa Gas Kitchen Range
Lost our power now on our range we have clock working timer working and burners working. Try to put oven on & the lock button lights up. Try to put broiler on & lock button lights up. Nothing goes...
Ive had the same problem after losing power. I heard to unplug and plug back in the oven and it should work- didnt work for me. Then Ive heard to replace the control board. I found it for $141 on appliancepartspros.com I havent purchased it yet, still searching to see if this is really the problem
Feb 20, 2011 | Maytag PER5710 Performa Electric Kitchen...
Elements and light in stove work but clock and stove do
The issue would have to be in the clock or the power wire going to the clock.
The clock controls the power to the oven elements and there are no fuses or other devices to control the elements.
May 20, 2010 | Maytag PER5710 Performa Electric Kitchen...
Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Nov 20, 2009 | Maytag PGR4410 Performa Gas Kitchen Range
"S A6" Error shows in the display
unaBLE to check/locate yor model number inthe maytag library, but you can check your manual( if you have it) or call the manufacture for a replacement of it. your unit is set in "sabbath" mode. "SAB" the book will explain how to get it out.
Mar 23, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
I was setting the clock on my maytag model # PER4311ACW stove/range and then a code "5 A6" popped up on the display and now the oven won't turn on altough the stovetop still works and the display...
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Aug 09, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
I was baking in my Maytag range when there was a loud popping noise and the oven stopped working. The broiler, clock and timer do not work either. The control panel will do nothing. The burners work and...
Well on most electronic controlled ranges with the problem your describing alot of time it is the clock that needs replaced. And yes most ovens have 2 ignitors.
Jul 11, 2008 | Maytag Kitchen Ranges
Sep 02, 2007 | Maytag MER5750 Electric Kitchen Range
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Maytag MER5750 Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
