Question about Hunter HEPAtech Air Purifier and Ionizer - Model 30027 Air Purifier
Hunter 30756 air purifier switches do not seem to operate. There is a lock sign on. How do I unlock the switches?
5 Suggested Answers
SOURCE: air purifier HUNTER 30200
I hope this is not to late. This is an old post. But I have this same air cleaner. It does prove difficult at first to open and it feels like you are going to break it.
On the sides about two to three inches down is a large indentation. Slide your fingers in there and gently but firmly pull the face plate of the air cleaner off. The air cleaner is as big as the front of the air cleaner. It will slide right out. I hope this helps.
Posted on Mar 02, 2008
SOURCE: lights still flashing after i replaced filter
You have to press the reset button on some models. The unit does not have any way of knowing you reset the filter -- you have to tell it.
Posted on Mar 23, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I need a manual for
Hi and welcome to FixYa, I am Kelly.
This should be your 8 page users manual:
http://www.appliancefactoryparts.com/content/pdfs/116668.pdf
If this answers your question would you at least say the problem is solved? Otherwise you will keep getting email notifications of where to find the manual.
Thanks for choosing FixYa,
Kelly
Posted on Jan 16, 2011
  • 4736 Answers
SOURCE: Can I get an owners manual for Hunter 30525 air
Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
Hope this helped you.
Posted on Apr 21, 2011
Hunter 30201 air purifier on light is on, fan not working...
may need to replace the fan on your air purifier most of them look like some sorta computer PC fan shouldnt be too hard to replace hopefully
Feb 22, 2017 | Hunter Air Purifiers
Hunter hepatech 40882 uvc air purifier won't turn after cleaned filters
Hello, this is Ava with Think Crucial.
Filter life counters should be reset each time the filter has change. If your air purifier has a reset button, press and hold the reset button until the lights go out. You may also unplug your unit from the power for 30 seconds before plugging it back on if your unit doesn't have a reset button.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 24, 2016 | Hunter Air Purifiers
I have a hunter air purifier model number 36316 and need to know how to change the filter
To change the wick filters of your humidifier:
1. Turn off the unit and unplug it from the wall outlet
2. Remove the tank for the housing.
3. Locate the 3 lock tabs in the base of the unit. Turn them clockwise until the base of the tab lines up with the indentions in the base and lift off the housing.
4. Locate and turn the lock tab clockwise on the base holding the wick fram. Remove the wick frame and set it aside.
5. Remove the old wick by pulling the bottom of the wick out of the frame first and discard.
6. Insert the new wick top first. Ensure wick is in between the tabs at the top of the wick frame then slide the bottom part of the wick into the fram, making sure not to crush the bottom corners of the wick.
7. Reassemble the unit and refill the water tank if necessary.
8. Turn the unit back on and resume operation.
http://www.thinkcrucial.com/search?page=1&q=hunter&type=product
Ava B.
Dec 16, 2013 | Holmes Products HAP422-UC Air Purifier
Hunter Air Purifier making screaming noise
Most likely the problem is a bad bearing in the fan motor.
May 31, 2012 | Hunter Fan Company 30251 Air Purifier
Owner manual for hunter 30747 Air Purifier
You may refer to this online manual for your model number to help you put back the filters in your unit.
Hunter 30747 Instruction Manual
https://www.thinkcrucial.com/search?type=product&q=hunter
Ava B.
May 19, 2012 | Hunter Air Purifiers
Can I get an owners manual for Hunter 30525 air purifier?
Apr 21, 2011 | Hunter HEPAtech Air Purifier and Ionizer -...
Home Depot Switch Doesn't Work. Does anyone know where to get a
Google search Hunter Fan Parts. Should find what you need, and have it in a few days.
Regards, --WoobieDog--
Jul 10, 2009 | Hunter 30216 3-SPEED FLOOR MODEL Air...
Cannot find manuel, need to reset after replacing filters.
How to reset Hunter quietflo air filter, won't start up.
Jul 10, 2009 | Hunter QuietFlo 225 Air Purifier
Air purifier locked in one mode
Hold both fan speeds for 3 seconds to unlock panel.
Dec 10, 2008 | Hunter 30755 Air Purifier
Air Purifiers Logo
37 people viewed this question
Top Hunter Air Purifiers Experts
Gerry Harvey
Gerry Harvey
richie46
Are you a Hunter Air Purifier Expert? Answer questions, earn points and help others
