Question about Electronics - Others
Istar korea can this reciver connect to cctv
  • 2,113 Answers
After researching your question to try and make any sense of it... i figured that it must be a satellite receiver. Are you asking if it can be set up for closed captioning?
Posted on Oct 20, 2013
Circuit diagram for Reyed RYD180-A01 12VDC 18 Output switch mode cctv power supply
I know the rating is under but most CCTV does not pull the full power.
The only method to confirm the CCTV is to connect you DDM in series in AMP scale and see what it use.
Jan 05, 2014 | AMP Fuse Cctv Dvr Power Supply Box
Istar korea x1500
I have the istar korea x1000 & x1500 and the ip tv channal is gone from list snd also need a user code iptv.how can i fix this problem.
Dec 28, 2013 | Electronics - Others
Removal iStar.exe application
Sounds like you encrypted the drive. Under Computer, right click the drive and format it. You will lose all your data and there is no way around this. Write your password down somewhere if you can't remember it.
Dec 21, 2012 | Electronics - Others
Does it supports any brand of cctv cameras or will there be any incompatibility with same brand..
It support all brand of CCTV.
for PTZ CCTV, It has to have the Pelco protocol so the WJ-HD716 can control the camera.
in that case, the connection will use the RS485.
Oct 19, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
Hi, I have a home network set up, desktop, laptop, iphone and ipad, I also have a cctv dvr on the network, the dvr is definatly on the network as I can veiw it on any of my devices, yet it is not listed in...
you will have to allow the devices in the router wirless or direct connectivity setup in the router it self. If the router does not have permission to connect the device they will not be allowed to connect.
log in to the router and set up each device accordingly.
Aug 07, 2010 | Gateway Cable/DSL Router - 4Port [ Belkin...
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
How to connect a maglock to a fire relay? I have to insure that maglock controlled doors release when the fire alarm is activated. I have a Ccure Istar panel and I think a apc pwr supply
On most fire alarm panels there are normally open and normally closed relays that will change state in the event of a fire. The negative power line can be ran through these relays to allow the maglock to be powered down in the event of a fire. The relay on the fire panel may need to be programmed to do this or it may come programmed by default which is usually the case. Hope this helps.
Sep 25, 2009 | I-Star PSU ISTAR|TC-550PA RETAIL (TC550PA)...
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Electronics - Others Logo
77 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
