Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
Sony KP-61V85 Rear Projection TV. Evidently Twin View has been frozen on my component input. When I hook up from a component cable, it shows twin view or split screen. But I don't have the original remote and it won't turn off. HELP!
  • Sony Master
  • 3,187 Answers
Go to picture control using the tv buttons it will say somthing like split screen or pip go onto that and turn off.
Posted on Oct 22, 2013
  • 184 Answers
SOURCE: Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Posted on Feb 13, 2009
  • 145 Answers
SOURCE: No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
Posted on Nov 10, 2009
  • 8457 Answers
SOURCE: arched lines in dark screens
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair World.com or Tvrepairkits.com have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Posted on Jan 01, 2010
ladywinn
  • 5138 Answers
SOURCE: Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Posted on Mar 18, 2010
  • 1619 Answers
SOURCE: sony kp-65w5510 rear projection tv power button malfuction
Replace bulb and clean cooling fans of dust is the first thing to do. if that doesnt work might start checking capacitors on the power supply.
Posted on May 10, 2010
Leakage in tuner
tuner may be bad, it is possible if rear inputs work to route signal to one of those inputs by using a box with the same type of connections the rear inputs have--bypass the tuner in the set with a box.
Dec 16, 2012 | Sony KP-61V85 61" Rear Projection...
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
I have a sony kp-61v85 color rear video projector and it has a red haze across the middle section of the screen like its out of focus. A tv repair man replaced 2 cv boxes and the picture got clearer and...
The tv have a problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resitors are dead.These parts on the tv convergence board,must be replaced to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Sony KP-61V85 61" Rear Projection...
Can only see an image using Twin View and colors are distorted
Ur convergence it dead.Know how to solders?Try these websites.Tv repair world.com,Tv Repair kits for convergence kit,use what in that kit.
Oct 30, 2009 | Sony KP-53HS30 53" Rear Projection...
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
My sony tv Comes on some times but then some times does not
On most of your rear projections you got GUNS and if there out of allignment or overheat you will get this error and it will need to be serviced.
Apr 22, 2009 | Sony KP-61V85 61" Rear Projection...
I have a Sony KP-61v85 projection set that wyou help meon't turn on
4 blinks is error code in KP-61V85 and shows problem as follows...
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
If you have no experience, don't put your hands in TV because TV has high voltage inside and electric shock risk involve.
Oct 12, 2008 | Sony KP-61V85 61" Rear Projection...
Sony rear projection 61in TV
Is there any incidents happen before the problem occur, like powersurge, or sudden electrical failure on your area..?
Jul 26, 2008 | Sony KP-61V85 61" Rear Projection...
Sony KP-61V85 background to HDTV Compatable Yes or No??
This TV is about 7 to 8 years old already and is not HDTV compatable.
Feb 13, 2008 | Sony KP-61V85 61" Rear Projection...
2002 Sony 57 inch XBR
YOU MAY NOT HAVE THE HD COMPONENT CABLES AND CONNECT THEM TO ONE OF THE VIDEO LINES..
Dec 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
