Question about Nordic Track Nordictrack C 1900 Treadmill Motor Control Board For Model Number
Squeaky Nordictrack C1900
I just got a treadmill from my aunt and it is normal when it runs without someone on it, but once you start running on it, it squeaks unbearably. How can I adjust/fix whatever is wrong?
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
See the video attached. lube the rollers bearing front+back . Test the drive belt motor for to loose or faulty belt, and fix it.
However if the problem persist, TIME to replace the old board deck.
God bless you
Posted on Oct 21, 2013
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
  • 103 Answers
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
Posted on Dec 16, 2009
  • 31 Answers
SOURCE: It squeaks when I am running on it
Tighten the 2 bolts that attach the hinge to the deck in the right front corner
Posted on Jan 16, 2010
SOURCE: nordic track c1900 catches everytime u walk or run
swflafitness - Your suggestion worked perfectly for me, thanks!
Posted on Nov 13, 2010
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
Posted on Jan 03, 2011
Stopped in Belt had been slipping smelled hot but motor was barely warm. Was 30 minutes into workout and machine stopped. Electric panel works but motor won't run.tilt works
time to lube the DECK belt, use WD-40 or grease. do it by each weeks. Try to loose the deck belt. in the way that you lift the belt by 2" with your finger. Otherwise, you must replace the belt+deck. See if the belt drive is to tight. And take time for maintenance the motor, replace the carbon brush+and lube the bearing.
Feb 08, 2015 | Nordic Track Nordictrack C1900 Treadmill...
Squeaky sound
LUBE inmedIATELY the deck belt +rollers bearings too. If the problem persist time to replace the complete deck belt board.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack Powertread 5.5...
Squeaky treadmill
If this is actually emanating for the running belt then their is too much tension on the belt at the end of the belt their are two holes this is where you adjust the tension by using a 1/4" Allen wrench. start unit run it at about 3.0 mph turn the wrench 1/4 rotation at a time counter clockwise on each bolt until the groaning stops know if the belt slips at this point then the belt has been stretched and a new belt maybe required. On the lubrication you will need silicone lube and that can be purchased at iconfitness.com
Apr 15, 2010 | NordicTrack E4000 Treadmill
Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Feb 05, 2010 | NordicTrack Exercise & Fitness
Incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Oct 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Nordictrack C 1900 Treadmill Motor Control Board For Model Number Logo
223 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
