Question about Pc Ware M748LMRT Motherboard
Manual pdf m748lmrt - Pc Ware M748LMRT Motherboard
Hi, i need update bios for m748lmrt moteherboard
Goto this site and scroll to midle there will be your driver update for bios,download it install it,restart
http://pcchipsusa.com/BIOS/7482K1220S.ZIP
Jul 26, 2010 | Pc Ware M748LMRT Motherboard
Forgoton bios password
remove the CMOS battery from the motherboard and re-insertr again....
Jan 15, 2009 | Pc Ware M748LMRT Motherboard
I need the pcchips m748lmrt audrio driver.
try this driver
if not I need to know what socket type the mobo is.
Hope it helps
Dec 26, 2008 | Pc Ware M748LMRT Motherboard
I'd like to know if its possible to boot a m748lmrt board from usb port
if you mean an operating system then yes you can providing the bios is upated first, go here:
http://www.updrivers.com/bios/Motherboard/PCChips/M748LMRT-BIOS/11174.html
hope this helps
regards
Nov 22, 2008 | Pc Ware M748LMRT Motherboard
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
M748LMRT
Here is a link to the PC Chips website, where you can download any of the needed drivers for your motherboard. You can also get manuals, etc, there too.
http://www.pcchipsusa.com/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=45&DetailName=Driver&DetailDesc=&CategoryID=1&MenuID=6&LanID=2
Cheers,
Nick
Nov 17, 2008 | Computers & Internet
Problema con cpu
Su placa madre apoyará los procesadores siguientes:
(Your motherboard will support the following processors:)
Pentium III 450~500MHz
Pentium II 233~450MHz
Celeron 266~433MHz
Buenos Dias
Oct 22, 2008 | Pc Ware M748LMRT Motherboard
VGA1 video adapter problem
I have M748LMRT motherboard which has Xcel2000 chipset. I want to know pinouts of ATX header J3
Dec 27, 2007 | Pc Ware M748LMRT Motherboard
Pc Ware M748LMRT Motherboard Logo
71 people viewed this question
Top Pc Ware Computers & Internet Experts
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
