Question about Home Security
I have a wayne dalton 3212 model 3000 have tried programing two cars with Homelink but it doesn't work. After clearing and then holding the button I wish to program and the button on the remote clicker simultaneously the red light begins to flicker slowly. It continues to flicker slowly until the light goes out about a minute and a half later. The key is in the accessory on position and both buttons are held in until the light goes out. It never goes from flashing slow to a faster flash. Tried it in a 2012 Altima and a 2010 Toyota same thing happened with both. Any thoghts? Thanks in advance for your consideration!
  • 49 Answers
SOURCE: Power Light Flashing - Machine wont Start - Whirlpool ADP5966
this is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Posted on Feb 21, 2008
ktkodama
  • 37 Answers
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Posted on Jan 20, 2009
SOURCE: the remote button flashes but the doors don't open.
I took the system off the car, and am back to the key. The original remote don't work.Any sugestion?
Posted on Jan 22, 2009
robmcd27
  • 423 Answers
SOURCE: Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Posted on Feb 11, 2009
SOURCE: Sears garage door keypad/remote programming problem
Hi All,
I had the same issue recently and here's what I found out (through a LOT of research) and the solution (yes, there is one!):
As described by many, when you can't get both the remote and the wireless pad to work together it means your garage door opener can accept both rolling code and billing code technology, BUT not at the same time. When you reset all codes (normally by pressing a button on the opener for a period of time e.g. 6 seconds or more), you erase all codes and remote "pairings". Then when you follow the manufacturer's procedure to pair again (which could be the wireless key pad first OR the remote first), the first pairing determines the technology for all subsequent pairings. Example: if your first pairing/programming was with the wireless keypad, and if it was rolling code technology (normally the case for newer models), then the garage opener will only recognize and accept rolling code for subsequent pairings. If your remote(s) are older (billion code technology) then the opener won't even recognize the signal (e.g. led won't blink when trying to pair/program).
And vice versa if you start with your remote after erasing all programming (then your keyless pad won't work).
But here is a potential workaround! For newer wireless keypads (e.g. clicker from chamberlain), you have an option to select the type of opener you are using as you do the initial password set up (normally indicated by a number e.g. 1 for models built after 1995, 2 for models built between 1997 and 2004, etc). Each choice is associated with a technology in the background (e.g. either rolling code or billion code). If you are programming your wireless keypad first after erasing all codes / programming, if you chose the "recommended" option for garage opener, chances are it will be rolling code and that means you won't be able to program your older remotes (billion code) after that. So how can you chose the option that will match your remote???
Here's what you do: start by pairing / programming your older remote first after erasing all codes / programs. That sets the technology (e.g. billion code). Then, go ahead and program your wireless keypad, but you may have to go through the process several times by trying the different options until you find one that works!
For me, I had to try 4 options before making it work. Options 1 through 3 (mind you, options #2 was the exact match for my garage door opener model but it would cause the problem discussed here e.g. wireless keypad would work but not the remotes) would not even be recognized by the opener in this procedure (LED would not blink), but it did work once I hit option 4.
I hope this will help you with your problem. Let me know if it's not clear. Cheers!
Posted on Apr 15, 2009
How do I reprogram a Wayne Dalton wireless keypad model 02-3039UH?
Usually by reading the instruction manual and doing what it says to do .at least it worked for my neighbor a few days ago .
Sep 07, 2015 | Wayne-Dalton Wayne Dalton 297138 or...
I cannot get my universal Clicker by Chamberlain KLIK1U to work with my Quantum 3212 garage door opener even though it says that it works with this model. I have followed the instructions and tried...
The klik1u does not operate at a 303mhz frequency therefore it will NOT program to the quantum 3212 but the actual remote from Wayne Dalton is only 2 dollars more than wal mart charged me for the klik1u when I bought it to try
Jan 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a 1990 Wayne Dalton opener with remote control model 61wd. it uses rolling codes. Everytime i try to add a my new KLIK1U univeral remote controller, the original controller quits working. When I...
The system is limited in the number of openers it can store. Usually 3 though I don't know about your model..
You need to clear all stored openers, and then re-add what you want to use. If there are 4 or more it will not work.. The last one entered will be replaced by the new one. (What you're getting now)
Usually to clear memory, hold down the program button for ten seconds or so.
Wait a few seconds, start installing your openers.
Good luck
Dec 27, 2010 | Chamberlain Clicker Universal Remote...
How to program my cars garage door opener buttons for my garage door.
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
May 15, 2010 | 2001 Nissan Altima
I have a quantum model 3212 serial #3000...fcc id #kj8intrmt...ok im trying to program my garage door to my truck..help please
1. In the vehicle press and hold the two outside buttons until the indicator light begins to flash (after 20 seconds). Release both buttons. Note: Some vehicles may require the ignition switch to be turned to the second (or "accessory") position during the programming process.
2. Hold the end of your handheld transmitter between 1 and 3 inches away from the Homelink surface (located on your visor or overhead console) keeping the indicator light in view.
3. Using both hands, simultaneously push the handheld transmitter button and the desired HomeLink button. DO NOT release the buttons until step 4 has been completed.
4. Hold down both buttons until the indicator light on the HomeLink Wireless Control System flashes, first slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light indicates successful programming of the new frequency signal.)
To train your garage door opener.
1. Locate the smart/learn button on the garage door opener motor head unit.
2. Press and immediately release the smart/learn button.
Firmly press and release the programmed HomeLink button. Press and release the HomeLink button a second time to complete the training process. (Some garage door openers may require you to do this procedure a third time to complete the training.)
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Programming car remote using garage door opener remote control fo
GOTO HOMELINK.COM
HOPE THIS HELPS
Jul 03, 2009 | 2003 Lexus ES 300
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
