Question about Pioneer Rx-590 Home Stereo Double Cassette Deck As-is Make Offer
Been trying to get the radio station to program.it hasn't been working. On my RX-590
    Top Expert:
  • Pioneer Master
  • 36,596 Answers
If you are using automatic channel search, disable it and use manual tuning to find the station then program it. If the signal you are seeking is comparatively weak compared to others, the tuner will skip it in the automatic search mode.
Posted on Oct 20, 2013
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
My baofeng radio will transmit but will not reseive
Check your settings for the RX frequency. Then check to see if the RX Tone is turn on and is set to the correct frequency. Just turning the rx tone off should allow you to hear any station coming in.
Aug 06, 2014 | Dual Uv-5r Baofeng Band Uhf/vhf Radio Usb...
3040 ck
It's a Uniden model 3040 CK, is this correct, if so then the problem is due to someone or something causing a carrier frequency to be received by your unit, causing the Rx to stay open, the fact you can Tx and Rx the other station you're communicating with, indicates that the radio is working as it should, the problem is caused by external interference and not in your radio.
I hope this has answered your query.
Regards,
Peter
Nov 10, 2012 | Uniden Radio Communications
I need a set of instructions for programming a JVC remote control, RM-SRX7010J so that I can select several FM radio stations using the remote control. My stereo receiver is JVC RX-7010V. Thanks in...
Hi Will,
If you want to store preset station so that you can easily select your favorite FM station, instructions on how to do this are listed on the JVC RX-7010 User Guide (page 20-22). Remote control operation is also listed there. It is to long to write here.
Please download and save the Pdf file format of the user guide HERE.
Enter your email add and the confirmation number and then click "Download Now" to automatically begin the download. It is a safe website, I used it personally.
Kind Regards,
Mjsazon
Nov 24, 2011 | JVC RM-SRX7010J Remote Control
Could you please tell me what COLORS that i need to put where when wiring a Superstar DM 452 to a Galaxy Saturn base station radio?
Don't worry about colors. look a the mic switch connections. one wire will be a common ground for TX & RX the middle wire would be ground(pin1) the n/c side will be RX pin4 the N/O side will be TX.... the same for the audio element side, one will be ground and the other will be audio pin 2.. this works for any mic and any radio.
pin1 ground pin 2 audio, pin 3 TX, pin4 RX.. standard pin outs cobra / galaxy/connex exports
Feb 26, 2011 | Radio Communications
Turner only selects odd numbered radio stations
this is the frequency settings that programmed in your audio system, reprogramming will be done your problem, if it cant be programmable install a device on antenna output(frequency modulator changer) you will pick-up all station you want but the problem is... the digital cant be set to appropriate radio station
Jul 22, 2010 | Yamaha RX-V663 Receiver
Problem with Vertex VX-820
Try "reading" the radio before programming it. It sounds like the programming software is using the settings from one radio to write to another. It's highly probable that the firmware is different on the two radios.
It's always a good idea to "read" a radio befor trying to 'write' to it..
Dec 14, 2009 | Vertex Radio Communications
Record from radio to cd
i don't think this stereo has a cd burner your best bet would be to use online radio (most stations do this now) record straight to your computer and burn cd from there
Jun 12, 2009 | Panasonic RX-ES25 Cassette/CD Boombox
Setting channels for am and fm on pioneer rx 570
Hi gbrokaw
Generally speaking, you select the station you wish to store, then depress and hold down the preset button you wish to store it to. After a few seconds, the screen will blink, and the will be station stored. On to the next one. Try this and see how you get on. If you have any problems, I am happy to help you help you sort it out. Cheers
regards
robotek
Nov 07, 2008 | Audio Players & Recorders
Pioneer Rx-590 Home Stereo Double Cassette Deck As-is Make Offer Logo
89 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
