Question about Toshiba Satellite L645D-S4056 laptop
Can't log into bios - Toshiba Satellite L645D-S4056 laptop
    Scholar:
  • 189 Answers
Try restarting the PC and tap the F12 key as it is restarting then it will should give you options for the bios.
Posted on Oct 21, 2013
Computer will not recognize bios password.
Unfortunately, this is a security problem. I would advise you to take it to a competent Toshiba Tech and with proof of ownership get him to remove the password for you.
Feb 24, 2014 | Computers & Internet
Howto clear log on server ibm
Server is model is not mentioned.
You can clear logs by this way..
1: Get into BIOS and there you could see server logs. Clear those logs
2: Get into IMM and you can find logs there. Clear those logs (This is applicable to servers with IMM and Uefi firmwares)
3: Get into BIOS and find out IPMI logs. Its under Advanced settings.
Clear those (This is applicable for older x series machines with BIOS firmwares)
Thanks
Nov 21, 2012 | IBM xSeries Computers & Internet
Bios password wont let windows boot up
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 13, 2011 | Toshiba Computers & Internet
I forgot the bios password also i want to update the bios in the laptop my currient version is f 39
when you boot up to the log in screen type in administrator to log in if you cant log in
During the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
or
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
Dec 04, 2010 | HP Computers & Internet
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
I was using my laptop and now for some reason I can't type on the keyboard or log off. Did I hit a key and lock it? How do I unlock it?
Use the touchpad and right click on the Taskbar then click on the Task Manager to open it. In the Task manager, click on the users tab to view the list of the logged on users then click on the username that you want to log off then click on the Log off button.
After logging off again use the touchpad to restart the Computer by selecting the appropriate option.
As the Computer is restarting press the button that says on the screen to press to enter to SETUP screen. This will make the Computer boot to the BIOS. In the BIOS check if the keyboard is working by pressing the arrow keys to select the Exit menu to select the restore to default option.
If the keyboard is not working in the BIOS then the keyboard is failed and service is required.
Nov 03, 2009 | HP 550 Notebook
I know bios password but i want to remove it without removing the battery
log in bios and set bios password again hitting enter
this will reset your current password
Jul 09, 2009 | Acer Computers & Internet
How to go to the BIOD set up
1. Restart your computer and while its powering up , keep pressing DELETE Key on the keyboard, this will take you to the BIOS screen.
2. Go to Advanced Setup, find the DMI logs option. This option may be located under different menus under different types of BIOS interfaces.
3. Once you locate the option, Select the option to Clear the DMI logs and also disable DMI logging if you don’t need it.
4. Save changes and exit from BIOS. Restart you computer.
Mar 12, 2009 | Microsoft Windows XP Professional
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Toshiba Satellite L645D-S4056 laptop Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
