Question about Fisher and Paykel Washing Machines
Hi - I have a Fisher & Paykel GW512 washing machine. it keeps giving an error showing these light on the cycle progress 01000010 (code 66)? I pulled the top off and if I disconnect the display module from the motor control module and then put it back together I will run again but for maybe only one complete cycle before the same error returns, idea or solutions?
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 224 Answers
I can't remember what fault 66 is off hand, but I can check tomorrow.
fault 130 (which has one extra 0) is a common fault, and will do what you say. it is an intermittant RPS fault. RPS is a small chip on the side of the motor, and they are a little touchy at times. easy enough to replace by removing motor cover, loosening the motor and removing the RPS from it's harness.
Posted on Nov 11, 2013
JULIANFIX
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
  • 28 Answers
SOURCE: Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Posted on Jun 21, 2008
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
BIKER T
  • 909 Answers
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
Hi my fisher and paykel washing machine is stuck up. When i turn it on it will stay on this mode-hold and the buttons won't work and won't even start. Can you help me solve this problem? Thanks
This is an old post I know
The wash progress lights are giving an error code. With zero meaning OFF and 1 meaning ON your picture shows an error code of 01000000
Switch machine off at the wall for a good 5 minutes. Turn on again and see if the same error again I am afraid this is what the service manual says::
64. (01000000) - Pressure Transducer Error - Frequency < 66 kHz
The Motor Control Module has received signals from the water level
sensor (Ptx) below normal frequency values.
Cause: Faulty Motor Control Module.
Action: Replace Motor Control Module.
The motor control module is found under the buttons panel. Undo the 2 screws at the back behind the buttons and the controller is underneath. You may have to pull the main lid off first to get the buttons panel off. Motor Controllers are not cheap sorry. They can be found on Ebay
MAKE SURE YOU GET THE RIGHT MOTOR CONTROLLER PART NUMBER ON THE STICKER. They may look the same but they are all different.
Unplugging the controller may seem daunting but count how many things you unplug and then you know how many to put back on. The plugs can only fit in their own sockets so you can not mix them up.
Hope this is of some help
Good luck
Jun 30, 2015 | Fisher and Paykel Washing Machines
Error code 66
66. (01000010) - Pressure Transducer Out of Range Error
The Motor Controller has received signals from the Pressure Transducer outside normal values.
Primary Source - Motor Controller
Action - Replace Motor Controller
Feb 11, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
I have a fisher and paykell GW712 washing machine that has the 2 green light and 7 red light flashing and beeping after turning on at power point.after pushing buttons 4 or 5 times and turning the power on...
The second light and the seventh light on and beeping is fault 66.
This is info on fault 66.
66. (01000010) Phase 6 - Pressure Transducer (Ptx)
Error - Frequency > 90 kHz
Note: this supersedes Fault code 65 from V41 Motor Control Module
code onwards.
sensor (Ptx) above normal frequency values.
Primary Source: Motor Control Module.
Oct 07, 2013 | Fisher Paykel EcoSmart GWL15
Fisher paykel gw512
sounds like the motor control board has gone. prob a blown fuse. you cant replace as is a small button type on circuit board.
Jun 20, 2013 | Fisher Washing Machines
My fisher and paykel gw708u is intermitantly filling then goes into alarm and stops
Your rotor position sensor could be faulty,
your error code should be on the wash cycle progress lights.
Nov 18, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
Gw712
code onwards.
Apr 22, 2012 | Fisher Paykel EcoSmart GWL15
F&P GW512 compact wont spin
Hi just read your posting.Does your machine drain the water out?Starting from left to right what lights were lit on the progress bar when it started to beep?Was it the 2nd and 5th or 3rd and 7th---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel GW612 beeps before spin.
You have fault code 66 (01000010) Phase 6- Pressure Transducer (Ptx) Error - Frequency >90kHZ. In simple terms you need to replace the main "Motor Control Module" Cheers
Mar 09, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
175 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
