Question about Fisher Paykel EcoSmart GWL15
Washer repair. Fisher and Paykel will not aggitate. Aggitator has been removed, but there was nothing underneath the aggitator.
  • 100 Answers
Hall sensor may be damaged on the motor or the control isn't sending voltage to the motor
Posted on Oct 30, 2007
How do you take the aggitator out of GWL15?
Possible that the control panel is faulty as there is no output to this cycle. You can check the voltage to the motor when this cycle starts so as to confirm the case. If so remove panel and check for some dry soldering if not the processor is a suspect.
check this link: Washing machine
Jul 03, 2012 | Fisher and Paykel GWL11 Top Load Washer
I cant lift trhe bottom aggitate plate in my hmwm8000 i have removed the cap and phillips head screw how tov lift the plate?
there should be a bolt holding aggitator on spines,if not try grabbing aggitator and pulling up while rocking aggitator back and forth it will require a great amount of force to remove aggitator fron splined shaft,also so penatrating spray may help sprayed on splined shaft.It also may need to be cleaned around splined shaft to clean built up soap build up. also a haet gun or a hair dryer on high heat on top of aggitator shaft when trying to remove may help!
Jun 12, 2011 | Washing Machines
Trying to remove aggitator from maytag atlantis I removed fabric softener part need to get the shaft of aggitator off trying to clean my softener keeps leaking out after wash is done
i believe all you have to do is put your fingers underneath the bottom of the agitator and pull up and the whole agitator pops up to remove it out of the tub.
Apr 08, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Washer was filling but not aggitating,
remove the dispenser in the top of agit . under it is a bolt. remove bolt. it holds it down . if it won't pull by hand then we use a ( agi tamer. this is a split inner tube type/very flat with a split in it . slide under agit and add water and up it comes . 5 min. .. i don't think something is under the agit I belive the trans is failing . but you need to look . . agit needs to be removed to repl trans anyway
Dec 12, 2009 | Maytag PAV2300 Top Load Washer
Washer will not aggitate all other functions work fine
Sounds like you need a set of dogs...(dog agits)...
Pop the top off the agitator and remove the bolt. Pull the agitator top off and inspect the dogs...(small tear drop shaped pieces of nylon)...
Sounds like the dogs lost their bite aka teeth.
Apr 11, 2009 | Washing Machines
Fisher & Paykel WA37T26G Washer
I have one and they are right. Both the drum and the agitator turn so that the clothes are not beaten up.
Also the electronic motor control is fully variable speed. It will go as slow as! Dial up for wollens and it almost massages them. The cycle time is 1/3rd of a front loader.
Jul 20, 2008 | Fisher and Paykel IWL12 Top Load Washer
The aggitator (sp?) isn't turning...the rest seems to be working (spin & fill). How do I fix it and is it worth fixing? Model LBT6133A Whirlpool Washer
Go under the aggitator inside the tub and pull out the aggitator it self and check out see if the teeth are strip,If the teeth are strip on the aggitator replace it. If is on the other side then it's not worth repairing. All you need to do is just pull on the aggitor from the bottom.
Apr 26, 2008 | Washing Machines
Aggitator is lose small items (socks) fall down behind aggitator
When the wash plate is loose (can be lifted up and down) it means that your washer needs a u-joint kit. Yes, Whirlpool actually came out with an entire kit for this.
Tightening the bolts (actually there are 6 of them) won't fix your problem. The kit number is 285927. There's an instruction sheet included with it.
After you get the kit and are ready to install it, remove the white plastic dome by inserting a flat screwdriver into the 4 small slots (look closely and you'll see them) and lifting up at the same time.
*Beware... this is a MAJOR job. Be prepared to spend a long time on it. You'll need to lift the top panel, remove the balance ring, remove the wash plate, remove the drive block nut (<---sometimes requires a torch), etc... It may not be something you wanna jump into. Call an appliance repair outfit and ask them what they'd charge to install one if you ordered the part.
Mar 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
103 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
