Question about Zoom 5790-00-03AG ADSL X7N Modem and Router with Wireless N Access Point
Is the system light suppose to blink all the time?
Garage door automatically reverses if you cross the safety beam when door is in upward travel
something is wrong supposed to reverse on downward movement only as not to crush you.. in upward not supposed to do that.. call chamberlain 800 number
Jan 25, 2015 | Chamberlain 1/2-HP Whisper Drive Belt...
2003 Ford Expedition - What do blinking red lights signify?
Do you have an alarm system installed? These sound like the alarm indicator lights. They are supposed to deter theft and break ins.
Jul 24, 2010 | 2003 Ford Expedition
My P-660HW is not turning on...power light blinks and goes off...
My guess is that you have bricked your device. Could be that you did not let the device finish its factory reset after you pressed reset and before you powered it down.
I might consider holding the reset button while powering it up - and checking the brick's voltage to see if the failure was coincidental, (but that should be a red power light) and then calling zyxel.
The manual says that if the power led is not on, "The system is not ready or has malfunctioned." The manual says that you are supposed to press the reset button when the led is green and solid, not when it is blinking, and you are supposed to hold it until the power led starts blinking, which might take up to 10 seconds. This is odd - and I do not believe that the Centurylink installers, who press these reset buttons many times a day (since the guy I talked to reset all modems as a matter of course before using them) hold them that long. But that is what the manual says.
Hope that helps, and sorry for the bad news. Maybe zyxel can help, have you tried contacting them?
Nov 11, 2009 | Zyxel Prestige 660HW Wireless Router...
On top of the model 704x amplifier their is a red light
Does it say protect under the red light? or power?
Oct 22, 2009 | Car Audio & Video
I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Jun 17, 2009 | Televison & Video
Mitsubishi WS-65511 HDTV
Well, this is how that set is supposed to work. After it is plugged in the LED should blink for 70 to 90 seconds. That is normal and is the amount of time it takes for the Digital Module to boot up. During 'boot up' time the set is inoperable. Once the LED stops the set should operate normally. If the blinking never stops there is a problem with the Digital Module. If the blinking does stop but the set wont come on there are other things you can do to narrow down why the set is not working.
Jun 02, 2009 | Mitsubishi WS-65511 65" Rear Projection...
ABS light blinking at idle
It's supposed to blink until you drive off for first time after starting the bike, it's a safety measure to ensure that the system is ok (it makes sure you know that it is there!) . If it keeps on flashing while you're riding you have a problem, but if the light goes out at about 5mph the ABS is fine.You can still ride it if the lights are flashing, you'll just not have ABS, just "normal" brakes
Apr 17, 2009 | 2004 BMW R 1150 R Rockster
Are front side marker lights suppose to blink
They are NOT supposed to blink only the front facing
Apr 04, 2009 | 1999 Ford Crown Victoria
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
LOST ALL POWER
How many times does the light blink red? It should blink so many times then stop then blink again. What's the sequence? This will help me determin where the problem is.
Jan 05, 2008 | Sony KDF-E55A20 55 in. LCD Television
Zoom 5790-00-03AG ADSL X7N Modem and Router with Wireless N Access Point Logo
151 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
