Curtisint com i have a tablet that wont charge,when i plug in the charger it still says to connect charger. What do I need to do
    Scholar:
  • 152 Answers
Check/ replace battery.
Posted on Oct 21, 2013
My hipstreet pulse 5v charger broke & i have bought several 5v needle chargers that plug into my tablet but wont register or connect to charge it why?
Hi yes the problem using different chargers polarity can be positive & negative. On the male plug or it can be negative & posative ....also they can be AC CURRENT OR DC CURRENT U NEED A MULTIMETER TO TEST THEM ...OR ITCOULD BE a fault with the tablet or the Charging socket .,cheers
Jun 22, 2016 | Tablets & eReaders
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
My tablet wont charge
If the cable has a micro USB connector (most android tablets do), then the connector is likely the problem. With the cable plugged in, there should be a light to indicate charging. It would usually be orange until charged, when it turns green. If you don't see the light atall, the connection is bad. Try wiggling it to see if that helps. If it does, then you will need to make sure the phone is charging somewhere so that it is not subject to being moved at all, which might cause the connection to become loose. The phone will charge faster if it is off.
Feb 03, 2015 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Dec 30, 2014 | Tablets & eReaders
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
Tablet wont charge
The charger socket has probably broken its solder connections, happens because of repeated movements straining it by using it when the charger is plugged in. Have you tried charging it through the mini usb socket?
Jun 05, 2013 | Samsung Tablets & eReaders
Battery wont charge on my Mid m9100 android tablet pc
Are you sure the charger is working correctly? When you plug the charger into the tablet and into the wall, then leave it alone for half an hour, does the charger feel at all warm? Is there power to that outlet, or is it a switched outlet (like one used for a lamp)?
If the charger feels warm after half an hour, does the back of the tablet also feel warm? It may actually be charging.
If the charger is dead cold (same temperature as a table) and you're sure that it's plugged into a good outlet and correctly plugged into the tablet, then it's a good bet that the charger is dead & you need to find another.
Can you also charge that tablet with a USB cable connected to a PC? That'd be a good test. Try doing that - if that ALSO will not charge the tablet, then there may be a problem with the tablet itself.
Mar 02, 2013 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
Motorola xoom wont charge
this is very common/same problem lots people having with their tablets, but i recently found solution for it.... try the following.
first connect ur charger to the table as you normally would do for charging, then connect the tablet to the computer through the USB wire (make sure charger and usb wire both must connected to the tablet) and it should start charging.... this seem awkward but will 100% work try it and see it urself
Feb 03, 2013 | Motorola Mobility XOOM Android Tablet
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
