Question about Echo 12 in. 25.4 cc Bar Telescoping Gas Pole Pruner PPT-266
Echo ppt-266 pole chainsaw will not cut with the pole extended
    Sergeant:
    Champion:
  • 320 Answers
A very common problem is that the tip of the drive shaft breaks off. If it cuts with the pole retracted and won't cut with it extended, than the drive shaft is pulling out at the clutch end or at the head. Try loosening the screws where the pole goes into the cutting head, stand the unit straight up and twist the cutting head to see if it drops down even just a little bit. After trying that, loosen the screws where the pole goes into the engine assembly and twist it there also. If this doesn't work, remove the pole at the engine end and pull the drive shaft out to inspect the ends of the shaft. Good Luck. George
Posted on Oct 21, 2013
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Chainsaw starts fine, but dies mid cut?
Immediately after saw quits, while everything is still hot. Sometimes ignition modules quit working when hot.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Loosen fuel cap when it starts to die, If that fixes it it has a fuel vent problem.
If you did nothing to the carburetor adjustments, are using a fresh (3 months or less) fuel mix with the same oil/fuel ratio, and are operating at the same elevation there is a reason your saw is acting up.
It sounds as though there may be a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor. HTH
Lou
Posted on Oct 12, 2009
  • 6468 Answers
SOURCE: Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
Posted on May 27, 2012
Wont start, getting spark. when plug is diped in fuel it turns over. New plug.
Adjustment needed on the carburetor.
Look for the H and the L needles on the carb. Take off any plastic limiter cover, they're there for epa reasons only...
Go on you tube. Type in " how to adjust a 2 cycle carburetor" and you should find multiple videos...
Easy bud... go get it
Oct 19, 2015 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
How to fix bar oiler
try cleaning the bar and all the oil gallaries in the bar and chainsaw body. Rinse the oil tank with varsol to clean dirt fron the oil intake strainer, reassemble and test. to test the oil pump leave the side cove, bar and chain off, start the saw and see if oil sqirts out when you rev the motor
Sep 29, 2015 | Echo PPT-265ES Pole Pruner
I have a ppt-260 that when cranked it runs at a high rpm without pulling trigger and does not return to idle, does anyones have a suggestion for a fix?
Check your throttle cable as it may corroded and has the carburetor held in full throttle position or someone has the idle speed screw turn all the way in.
Nov 22, 2014 | Echo Ppt-260 Chainsaws
How to start Echo ppt-266
Fill with correct fuel/oil mix. turn switch to I. Pump primer bulb 4-5 times. Turn choke on. Pull starter until engine fires. Turn choke off. Pull Starter until engine runs & allow to warm up for 10 secs before trying to engage throttle. If it doesn't start after 3-4 pulls with no choke then try same sequence again. May have to use 1/2 choke after engine fires. If it still won't start then something is wrong with it & it will need to be checked by a service agent.
Jun 19, 2014 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
I have a echo cs 4600 chainsaw & am having problems with starting the saw. When it sits for awhile it starts up, but when you shut it off it will not start again. I check the plug and it is wet with...
First thing to do is a new plug.Also clean the air filter.Might help?When you take the plug out.Look down the hole to see if there are any scratches on the cylinder?usually muffler side is where they will be if any.I had one doing the same thing.It was blowed up.Needed a new piston and cylinder.Hope yours don't?
Mar 06, 2011 | Echo Garden
How do you test the ingition coil on a echo 16 inch chainsaw?
Remove the ignition switch wire from the module. Set the module pole gap by turning the flywheel magnets under the module poles, insert a thin business card into the gaps, and loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the gaps don't close up at any point. Test for a blue, snappy spark at a fresh plug gapped 0.020". If nothing or very weak, replace the module. Hope this helps!
Nov 08, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Jan 07, 2010 | Remington Electric Pole Saw
Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Mar 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Echo 12 in. 25.4 cc Bar Telescoping Gas Pole Pruner PPT-266 Logo
186 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
