Question about Casio Office Equipment & Supplies
Argument error - Casio Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
You provided an invalid argument to a function, such as a negative number to square root or a number greater than one to arcsine.
If you need further details, please specify the model of your Casio calculator and the exact function and the argument you provided.
Posted on Oct 21, 2013
E:failed to mount Galaxy J7 J710F?
your phone may be damaged now, So, I think that You have to install Stock Rom again. your phone will not avoid warranty. Stock Rom is default and official Rom. - Stock Rom.
Jul 08, 2016 | Cell Phones
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
Graphing calculator argument error
The function you give as example in the additional information to your duplicate post is too simple to generate an Argument error. Maybe a syntax error but not an argument error.
Check what you enter on the line that defines the function. Do not confuse the minus sign - (for subtraction) and the change sign (negation sign) marked (-).
You can also reset your calculator by pressing the button on the back.
Mar 09, 2014 | Office Equipment & Supplies
Err domain
You tried to use an argument to a function that was not in the function's domain. For example, the arcsine function takes an argument from negative one to positive one. Trying to take the arcsine of 2 will generate a domain error.
If you need further assistance, please specify the exact function and argument that is generating this error.
Oct 15, 2013 | Texas Instruments TI-83 Plus Calculator
WHAT IS ARGUMENT ERROE.?
Take for example a function y=f(x). What is inside the function is called its argument (what it is acting on). If you get that error it may mean that the argument type is wrong or that it is out of range. Here are two simple examples.
  1. A function requires a real number and you make it act on a complex number (wrong argument type).
  2. You know that the log () function must have a positive argument and you try to calculate say log(-2.5).
  3. Arc sine and arc cosine must have an argument in the closed interval [-1,1] but you call them with a value outside that interval.
  4. A function is defined with a list of arguments yet it is called with more items in the list or less items in the list.
Try displaying the values of the arguments before the function is called. This way you will see if you are passing it correct arguments.
Apr 09, 2013 | Casio Fx-5800p Programmable Scientific...
When I attempt to use hyperbolic functions for complex numbers i get a domain error
Have you checked the calculator's manual to see if the calculator is able (natively) to handle functions of a complex argument. It is able to handle simple algebra with complex numbers, powers, roots, solving a polynomial equation.
For this calculator, the hyperbolic functions must have a real argument otherwise you get a error. But just to make sure, try the exponential function with i (imaginary unit) as argument. If it comes back with a domain error you have your answer.
Apr 06, 2011 | Texas Instruments TI-89 Calculator
Integration, too few arguments
I reset my calculator and this solved the problem. To reset your calculator press [2nd], then [6] (Mem), press F1 (reset), Select 3 for all memory, and select Yes.
Oct 23, 2008 | Texas Instruments TI-89 Calculator
121 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
