Question about Garden
The mower starts fine but when I take my foot off the clutch pedel or keep my foot on the petel and pull the elec. clutch for the blades it stalls
    Sergeant:
    Champion:
  • 320 Answers
The switch located under the seat is NORMALLY the cause of this problem. Disconnect it, trip it out with a jumper wire and then with the clutch lock in, try and start it. If it starts the switch is bad. If it doesn't, Plug it back in and then go to the clutch switch and do the same. Being it shuts off when you pull the blade engagement switch I think its your seat switch, but don't hold me to that. Thanks. George
Posted on Oct 21, 2013
I have a 2011 Craftsman LT2000 Model # 247.288851. The blades will only engage when I raise the deck to level 5. Ive replaced the Seat Safety Switch so Ive eliminated that. Help please! Lol
what actually engages the blades an electric clutch or a manual lever both of my craftsman mowers have elec clutch and when you pull the button the blades run deck height has nothing to do with it .
Apr 08, 2015 | Craftsman Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a yth2448 , and when I engage the mower blades the elec. clutch is drawing to much electricity (the alternater gauge drops to negative when I pull the knob to engage the blades and its draining the...
Disconsolate the connector from the clutch. Engage the clutch circuit and see if electrical circuit still response as if shorted.
If the response is the same check wiring, switch and relay. Replace/repair defecrive component.
If the response is no problem check the clutch. Inspect the connector at the clutch for broken failed wire connection. Using an ohm meter check for short. The expected resistance is about 3 -4 ohms. If the resistance is less then 1 ohm the PTO clutch is bad. Sorry. It is the solenoid coil has an internal short. Confirm if the clutch is still in warranty.
Check for after market sources for reduced price!
s-l1600-ye4zlyuovxg25rnpc03q42bj-3-0.jpg Hope this helps?
Jun 23, 2017 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My sears craftsman riding mower will crank just fine, but as soon as I try to either put it in gear and release the clutch to go forward or backward, it shuts off. It also shuts off when I attempt to...
Many folks have found that a defective relay in this mower to be the cause of the "stall when i take my foot off the clutch" issue. The relay is connected to the safety switches which turn the mower off when no one is in the seat, etc.
Aug 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I ran over a cable-wire with my Craftsman 7 hp ohv front drive mower and it stalled out.\r\nI removed the cable and now the blade seems as though it seized, can turn the blade to a point and no futher....
Bent blade, bent mower deck or bent crank shaft.
Unbolt the blade, check under the spacer plate , and set blade on a flat surface to see if warped or bent.
Remove spark plug wire and pull start cord to see if motor will rotate. don't need to start. If pulls free then look for obstruction or dent.
Jun 11, 2010 | Craftsman Garden
Started my truck this morning..it was stalling out 2-3 times.. then the cluch pedel went to the floor. pulled it back up with my foot. now it is working fine. ?
Sounds like your clutch master cylinder, or slave cylinder or actuator seals failed. Most likely the actuartor. Check the clutch lines for fluid leaks. It could probably happen again and you might not be so lucky this time.
Nov 19, 2009 | 1993 Ford F150 SuperCab
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
