Question about D-Link DIR-600 Router
Cannot connect to wireless printer. Advises to disable MAC address filtering but I cannot get into Dlink files to search filters. Where do I go from here?
    Master:
  • 359 Answers
Are you able to login to the router itself to change the MAC address filtering settings. Usually routers have default IP addresses of 192.168.1.1 or 192.168.0.1. Try either of these addresses in your browser and the login should be admin with password admin, unless it was changed by someone else. Then you will need to get the login information.
Posted on Oct 20, 2013
SOURCE: mac address filtering problem
router has a reset button. of course!
Posted on Mar 04, 2008
  • 53 Answers
SOURCE: dlink wireless router, shows up, can't connect
the manual can be downloaded from the dlink website;
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
you are also able to get a couple of utilities from the dlink website; it's a very long link but this is the location for the relevent files.
http://www.dlink.co.uk/?go=jN7uAYLx/oIJaWVdDbgYU93ygJVYLelXSNvhLPG3yV3oVYx+g6ltbNlwaaRp7jksED2onGQTo48EE5+3n/K9K0MH8LubPtqzEMT8pnRbyctCCrpHKcCVuErk6TGEOcGXYPgp/FUnrIBfqygTYYTwlmHkgyBavmKsERo=
the formatting is messed up but just copy and paste into you web browser.
Posted on Nov 11, 2008
beeveez
  • 167 Answers
SOURCE: ichat not working
- Setup the required ports of the MAC Ichat on your router
Posted on Mar 08, 2009
  • 457 Answers
SOURCE: Please help.... I have just purchased a dlink
For setup, you need an Ethernet cable connection to the router, WLAN needs to be configured first before you can use it to administrate the router.
Quick installation guide is here: ftp://ftp.dlink.de/dir/dir-600/documentation/DIR-600_revb_qig_multi.pdf
The default user name is "admin" with empty password.
If you suspect the settings are not at factory defaults, press the reset button at the rear for 20 seconds with the router powered on.
Posted on Feb 09, 2010
  • 107 Answers
SOURCE: trouble replacing a USB modem with a Dlink 615 on Virgin Media
First: Turn off your USB modem.
Second: Setup your D-Link for connection
Posted on Mar 05, 2010
Ll i need to put password to my accese point (dlink) please tell me how ?
Setting up a wireless router with a Windows client can be complicated.
There are a number of measures and options that have to be understood, and it's all too easy to make a mistakes but D-Link provides an easy to walk through configuration system to help you set up your D-Link wireless router.
Plug one end of the Ethernet cable into the DSL modem.
Then plug the other end into the "WAN" port on the back of the D-Link wireless router.
Connect wired computers to any of the other Ethernet ports on the router using another Ethernet cable.
Access the D-Link Configuration Screen
Open your web interface and type "http://192.168.0.1" into the address bar, then hit "Enter" or "Return."
Use "Admin" as the username and leave the password blank when the login screen appears.
Click "OK." You should now see the D-Link configuration screen.
Set Up General Security
Change your administrative password by clicking on the "Tools" tab and choosing the "Admin" button.
Enter a new password under the "Administrator" heading.
Confirm it, and click "Apply."
Disable the wireless Local Area Network (LAN) if you don't need to use the wireless access and you want to make sure no one else is able to access your network.
Under the "Home" tab, choose "Wireless" and select the "Off" option.
Enable Wireless Encryption Protocol (WEP)
Locate the "Home" tab in the D-Link Configuration screen, and click on the "Wireless" button.
Use the "Open System" button beside "Authentication."
Select the "Enabled" button next to "WEP," and set the encryption key to "128 bit."
Set the "Key Type" to "ASCII" and choose a 13-digit password for the "Key 1" field.
Write down the password in a secure location.
Click "Apply." Change the SSID
Change the SSID to make it more difficult for others to locate and use your network by clicking on the "Home" tab and locating the "Wireless" button.
Change the default SSID to one of your choosing, then click "Apply."
Disable SSID broadcasting. Under the "Advanced" tab, click on "Performance" and check off the "Disabled" box. Again, click "Apply."
Filter MAC Addresses
Click the "Advanced" tab in the D-Link "Configuration" screen and select the "Filters" button.
Choose the "MAC Filters" and click on "Only Allow Computers with MAC Address Listed Below to Connect to the Network."
Enter the name and MAC address of the computers allowed to access the network, beginning with the one you are currently configuring. Click "Apply."
Feb 19, 2014 | D-Link DAP-1522 Xtreme N Duo Wireless...
I am not sure if it is a case of mac filtering. I recently got my iPad2 and it sees the dlink signal but "failed to join". I did not have a problem with the laptop and notebook with windows 7....
It could be, you need to check the D-Link's wireless settings and see if MAC address filtering has been enabled. If so then you need to add the IPad2 wireless card MAC address to the list of MAC address in the D-Link's MAC address table.
If MAC address filtering has not been enables then the D-Link's SSID and encryption (WEP or WPA or WPA2) settings need to be entered in the iPad2 wireless settings.
Have a look at the wireless settings in the laptop and notebook, these should be the same and you can apply these settings to the iPad2.
Apr 12, 2011 | Computers & Internet
I have Kindle 3 WiFi and cannot connect to my Linksys WRT54GS in my home. How do I change the setting to allow MAC access? Thanks!
Hi, the MAC address filtering settings can be accessed by logging into your router's configuration software (type 192.168.1.1 into your web browser and hit Enter, then type in your username and password) and going to the Wireless tab and beneath that, Wireless MAC Filter. You can either choose Disable to turn the MAC filter off completely, or you can choose Edit MAC Filter List and add your Kindle's MAC address to the list of approved devices.
Jan 19, 2011 | Amazon Kindle 3G
How to lock dlink router DIR-600 so neighbors can"t connect?
The simplest way is to make sure wireless security is set up, so that users must provide the proper key before they can connect. You can find the user's manual here, which explains the process.
If you're willing to go a step further, you can turn on "MAC address filtering". The MAC address is a unique number assigned to the network interface hardware of the computer, and MAC address filtering blocks access for all wireless users except those you add to the list. If you want to allow only a few computers to use your wireless network (family members' laptops, or friends who may come by, for instance), this is the best way to do it. Then, even if someone guessed the security key, they still couldn't connect.
Jan 01, 2011 | D-Link DI 514 Wireless Router (DI-514)
Enabled MAC address filtering and no cannot access the internet
You have to connect to your router using an Ethernet cable. MAC address filtering is for wireless connections only.
After you connected via a cable, you can log in to your router and correct the settings. Make sure to follow the instructions in the manual from page 2-11 to 2-13.
If you don't have a manual, you can download it here. Choose the correct model, go to the "Documentation" tab and choose "User Manual".
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 06, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
MAC ADDRESS FILTERING MAY BE ENABLED ON MY WIRELESS ROUTER?
should be an option in the console (in browser go to 192.168.0.1 or 192.168.1.1, etc)
MAC Filtering just means that you can set up a set of MAC addresses (Machine Address) of units you want to be able to access your network. If you didnt set the MAC of a unit it will not be able to join the network. So mac filtering is a way to limit connection with your network.
For future assistance please visit http://www.hoosierpcrepair.com
Jun 22, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Temporarily Disable MAC address
Open the Router page using the following steps:
1. Open the browser (Internet Explorer or Netscape).
2. Access the Router (usually "http://192.168.1.1";
or "www.routerlogin.net" or "www.routerlogin.com").
3. LOGIN TO THE ROUTER (User Name = 'admin', Password = 'password';
unless you have changed it).
and then click on advanced wireless settings...
Click on setup access list..
Uncheck "TURN ACCESS CONTROL ON"
This is the process to disable MAC filtering..
In case u need further help u can contact me..
Apr 27, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
I have a dlink w-1310. I turned mac filtering off so that two iphones and a playstation can get on the wifi network. I would like to allow these addresses to the network and have my mac address filtering...
Are you talking about network places in a Windows Operating System?
Can you get into your DLink Router?
If you can directly get into the Dlink router, you will be able to determine what the mac addresses of those devices are, in the DHCP list table. You must have the devices on and connected to the network for them to be listed. From within the DLink router, you can also turn on mac filtering.
For exact details, visit dlinks website: www.dlink.com for the support manual for the router.
Feb 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Brother printer and Neygear router wireless connection bad.
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Feb 21, 2009 | Brother MultiFunction Center MFC-440CN...
I tried to set up HP Photosmart C4580 printer/scanner/copier with my Airport Extreme. However it is not connecting to the Airport Extreme. Diagnostic check recommends temporariiy disabling the Mac Address...
MAC address filtering is used to prevent unauthorised people getting access to your wireless network. you need to get into the Airport Extreme configuration using Internet Explorer or any other browser, then select wireless setup then MAC address filtering. You need to turn off MAC address filtering.
Check your manual on how to configure your Airport Extreme.
Dec 02, 2008 | HP Office Equipment & Supplies
D-Link DIR-600 Router Logo
35 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
