I cant remove the hexhead stud that holds the agitator on.
  • 3 Answers
If your machine is a top loader-- i've had good resuls with a strong socket ,an extension for height , and a bresker bar with a piece of pipe over the ans of the breaker bar for more torgue.
Posted on Oct 20, 2013
I cant remove thehex head stud that holds the plastic agitator onto the agitator shaft.
Could be a left hand thread to prevent it from loosening during normal operation.
Oct 20, 2013 | Kenmore 24032\24036 Top Load Washer
My Maytag A284 washer is making a terrible noise while agitating. It spins fine and everything else is fine except for the agitating. How do I get the agitator off to look and see if something is caught...
To remove that agitator look at the bottom paddles on it...one of them will have a small round hole on that side where the hole is about 3 iches up is a place where a screw is,it's a 1/4" hexhead screw remove that screw and the agiatator will pull off
If you dont see that hole(its small) it will still come off the same way just look on a 4 sides about 3" up and that screw will be there
GENE
Sep 11, 2011 | Washing Machines
How do I remove the agitator from my Kenmore Washer model number 110.24962300 to clean under it as clothes are coming out with flakes of dirt and soap-scum pieces etc. on them?
Follow these detailed step-by-step instructions to help you locate and replace your Kenmore worn agitator cogs:
  1. Before you begin this or any other repair, disconnect the power supply to your washing machine. Either unplug the unit from the wall outlet, trip the appropriate switch in your fuse panel, or remove the correct fuse from your home's fuse box.
  2. Raise the lid of your washing machine, and if your model uses a fabric softener dispenser, remove it from the top of the agitator by pulling it straight up and off.
  3. Pry off the agitator's cap (if there is one) by wedging a small flat head screwdriver into the slot between the agitator and the cap.
  4. Reach into the agitator top and pull up on the barrier cap and its seal (also called a gasket) to remove them.
  5. Use a socket wrench with an extension or a nut driver to remove the stud and the seal that hold the agitator top to the shaft of the agitator base.
  6. Remove the agitator top by pulling it up off the agitator base. Turn the agitator top over, enabling the cam and the worn directional cogs to slide out. Examine the cam for wear, it also may need replacing.
  7. Attach each of the new directional cogs to the cam. The small round piece at the base of each 'ear' is fitted into one of the cam's four slots. Your model may or may not make use of a black plastic agitator cam bearing. This cam bearing is used to help hold the cogs in place. If your model uses one, make sure you put it back on during the reassembly process.
  8. Carefully insert the cam and new directional cogs into the agitator top the same way they came out. Place the agitator top over the agitator base. There are tabs on the top of the agitator base that line up with, and fit into, the slots of the cam.
  9. If the cogs fall out of place during re-assembly, you will have to take the cam out of the agitator top again and re-insert the cogs.
  10. Push down on the cam until its slots and the base's tabs snap together.
  11. Insert the stud and seal into the shaft and use your wrench or nut driver to tighten.
  12. Make sure the black rubber gasket (seal) is situated properly in the groove of the barrier cap. Then push the barrier cap and seal down into the agitator past the holes.
  13. Replace the agitator's cap or fabric dispenser, whichever your model uses.
  14. Close the lid of your washing machine. Reconnect the power supply and test the machine to make sure it is working properly.
That should do the job for You. Hope this was helpful
Jan 14, 2011 | Washing Machines
The bottom part of the agitator seems stuck. It won't spin during a normal wash cycle and it won't budge when I try to move it when it is not on.
Small garments can get caught under the bottom agitator. Disconnect power then remove the agitator cap to expose the agitator bolt. Using a small flat-head screw driver, insert it between the agitator and the cap then pry the cap off the agitator. Remove the barrier cap if present then remove the stud and seal holding the agitator to the shaft using a 7/16" socket wrench with extension. Once the stud and seal are removed, lift the agitator off the shaft. You may need and extra shear of force when pulling the agitator off the shaft.
You don't have to accept or reject and rate this post to add information, comments, and follow-up questions. But accepting the solution will not terminate your communication with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Oct 31, 2010 | Washing Machines
Take brakes off
fronts: remove tire and wheel, there are 2 guide hold down pins ( screws ) on backside of caliper that remove with a Hexhead or torx bit. You may be better off renting the driver for this available from most parts stores for deposit only. Disc pads will then be able to pop loss with a pry of some sort. replace in reverse order.
Backs are pretty much the same if Disc , if drums remove wheel and tire assembly which exposes the drum. There may be clips on a stud or 2 , pry off. Tap the outside of drum around the edge but not so close as to damage edge, this should free any rust and drum should then be able to pull off. Remember exact order yo remove parts and springs on rears as they will only work one way,,In order.. You will need a few special tools to ease job. Spring retainer pliers to remove retaining cups on springs that hold down brake linings, vise grips do work with some luck. small screw driver to adjust play on backside of brake housing plate. Get yourself a repair manual also. Available from most libiarys for take out.
Feb 19, 2010 | 1995 Geo Prizm
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
Agitator wobbling from the stem. it comes right
Those are the agitator dog ears. They have teeth that grip and turn the top agitator during the wash cycle. It must be replaced when damaged or worn.
  1. Unplug the washer.
  2. Remove the fabric softener dispenser by pulling it off the agitator top.
  3. Look for the prying location on the agitator cap and insert a flat blade screwdriver between the agitator cap and the agitator then pry the cap off.
  4. Use a socket wrench, usually 7/16", with extension to remove the stud and seal holding the agitator to the shaft.
  5. Pull the top agitator from the bottom agitator.
  6. Pull the cam that holds the agitator dog ears from the top agitator.
  7. Lay the cam on its top and install the agitator dog ears on their slots.
  8. Hold the cam on one hand and the top agitator on the other.
  9. Slide the cam up into the top agitator and turn it over so that the agitator dog ears do not fall off.
  10. Reinstall the top agitator into the bottom agitator.
  11. Reinstall the agitator assembly into the shaft.
Jan 11, 2010 | Maytag Washing Machines
Everything works but the agitator
The small plastic pieces that are located under the agitator center cap that grip the agitator and turn it during the wash cycle are worn out. They are called agitator dog ears or clutch dogs. They must be replaced.
  2. Remove the fabric softener dispenser, if there's any, by pulling it off the agitator top. cf99d03.gif
  3. If no dispenser is installed, insert a flat screwdriver between the agitator and agitator cap. Pry the cap off the agitator then remove the upper part of the agitator. cae2ce0.gif
  5. Use a socket wrench with extension or nut driver to remove the stud and seal holding the agitator to the shaft. 96cc7e9.gif
  7. Turn the agitator mover over on your palm. The cam and agitator dogs will come out on your palm. Pay attention to how the agitator dogs are installed. Remove the worn agitator dogs and install the new ones. c8eb889.gif
  8. If the agitator dogs are not worn, check the agitator shaft. Remove the round rubber seal off the top of the agitator and remove the agitator by lifting it straight up. Call up service if the shaft is worn. ca89530.jpged86a35.jpg
  9. Reinstall the agitator. Rotate it until the grooves on the agitator matches the grooves on the shaft then push the agitator down.
  10. Place the round rubber seal in the groove on the top of the agitator. 5314b95.gif
  11. Turn the agitator mover over and carefully insert the cam and agitator dogs up into the agitator mover until it stops. c55998d.gif
  12. Carefully turn the agitator mover over in upright position.
  13. Place the agitator mover with the cam and dogs over the agitator, lining up the tabs. The cam has a cut-out and tabs across from each other. The agitator has tabs across from each other. All of these must line up in order for the cam to slide down on the agitator.5f7e245.gif
  14. Push the cam down until the tabs snap together.
  15. Put the upper part of the agitator back.
  16. Using a socket wrench with extension or nut driver, insert the stud and seal through the agitator into the shaft and tighten it.
  17. Push the barrier cap and seal down into the agitator mover all the way. Make sure the round gasket is in the groove in the barrier cap. The barrier cap must be pushed down past the holes on the mover to allow the liquid from the dispenser to flow.
  18. Press down on the fabric softener dispenser or cap until it is all the way down on the agitator.
Nov 30, 2009 | Kenmore 24622 Top Load Washer
I have a Kenmore washer that has trouble agitating. I took off the cap on the agitator and tightened the bolt that goes into the agitator. This fixes the problem for a while. Pretty soon the agitator...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are two "bolts" for the agitators (assuming that you have the basic split system) The bottom agitator turns back and forth and the top section only turns one way.
The top section (when you remove the cap) usually has a plastic 1/2" square drive bolt.
If you remove the bolt and top section of the agitator, you should see a second 5/16" stud. under the stud is a rubber washer.
The first thing I'd do is pull both parts of the agitator and look at the splines inside of the lower agitator and the splines on the transmission agitator shaft. If either of them is worn / broken, your washer won't agitate. Also make sure that the two pronged "washer" is in place on the transmission agitator shaft and that the clip that holds it in place is fit.
If the splines are OK, I'd carefully put the lower agitator back on. Check the condition of the rubber washer on the stud. Install the stud and do not over-tighten.
Put the top agitator on tighten the 1/2" bolt carefully. Don't over-tighten.
Beyond that, you may be looking at a clutch or transmission problem.
Oct 07, 2009 | Kenmore Washing Machines
One part of agitator moves the other part doesnt.
Two-Piece Agitator: Bottom Works, Top Does Not - Whirlpool brands
Some Whirlpool brands washing machines employ a two piece agitator. The bottom is call the agitator and the top is usually referred to a 'Mover'. A multi-piece cam and bearing assembly connects the two and allows the top portion to index.
If the bearing or cams become stripped or damaged, the mover will often not work. Fortunately, Whirlpool produces a cost effective agitator repair kit that replaces all of the critical components in this cam assembly. There are three different repair kits. They differ in the height of the cam.
Agitator Removal Instructions:
Remove Dispenser or Cap:
Some models of washing machines utilize a fabric softener dispenser that resides on top of the agitator. This dispenser simply snaps onto the top of the agitator. Other styles utilize a decorative cap. To remove the dispenser, simply grab it and firmly pull up. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (mover). Use a twisting or prying action to pop the cap off of the agitator.
Remove Internal Debris Cap:
Inside the agitator you will see a cap with a raised handle, much like that of your automobile. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring.
Remove Agitator Stud:
When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt (agitator stud).
Remove the Upper Agitator (Mover):
With the bolt removed you should be able to remove the upper half of the agitator (mover) by simply pulling up. Sometimes pulling up will actually remove the whole agitator assembly. If this happens, place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator.
Remove the Cam and Clutch Dogs:
When you remove the upper agitator (mover) it contains the cam and clutch dogs. Tun the assembly upside down. The cam and dogs should then come out.
-- Stop Here if Replacing Cam Kit --
Remove O-ring:
The lower agitator remains on the transmission shaft. On the top of the agitator, there is an o-ring. Remove this o-ring.
Pull the Lower Agitator:
All that remains is the lower agitator. This can be removed by simply pulling straight up on the agitator.
Agitator Installation Instructions:
Set Lower Agitator:
Slide the lower agitator onto the transmission shaft. Rotate the lower agitator until the splines in the shaft match those in the agitator. Once aligned press the agitator down. Install the o-ring into the top of the lower agitator.
-- Start Here if Replacing Cam Kit --
Assemble Cam and Dogs:
Turn the cam upside down. Place the small round ear of the dog into the corresponding slot on the cam. Repeat this for each of the four cams.
Install Cam and Dogs into Upper Agitator:
Invert the Upper Agitator (mover) and slide the cam/dog assembly inside. The cam should be pushed into the mover until it shoulders. Then rotate the whole assembly upright.
Install the Upper Agitator (Mover) on the Lower Agitator:
The lower agitator has two tabs that stick up that are 180 degrees apart. These tabs fit into two slots on the bottom of the cam. Align the matching tabs and slots and place the Upper Agitator (mover) and cam assembly onto the lower agitator. Push down until the cam snaps onto the Lower Agitator. If the dogs fall out during this step it is necessary to return to the 'Assemble Cam and Dogs' section above and start over.
Install the Agitator Stud:
Place the bolt (agitator stud) into the hole in the bottom center of the cam. Use a socket kit or nut driver to tighten the bolt .
Install Internal Debris Cap:
Install the o-ring into the groove on the OD of the debris cap. With the o-ring in place, push the cap into the Upper Agitator (mover). It is important that the cap is pushed past the ports in the Upper Agitator (mover) so that the wash water can enter and exit as designed.
Install the Dispenser or Cap:
The final step is to replace the top cap. Both the cap and the dispenser simply snap into place. Just make sure they are installed as far down a they will go and are firmly in place.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
