Question about Samsung DV330AEW Dryer
My dryer is showing an hour glass symbol on its screen. What does that mean
Hour glass symbol dryer not working
DUH make and model missing in the question and MP3 players are not dryers of any type
Aug 07, 2016 | Audio Players & Recorders
What does it mean when there's an hour glass on the display? It stopped running last night and there's an hour glass?
It means ''wait'' (seriously).
The question is: ''why is it displaying that message?''
If it is _still_ displaying that message. Try unplugging it for 24 hours.
If after that it _still_ displays that message, you may have a bad computer board.
May 18, 2015 | Dryers
My 2005 dies when I'm driving 40 mph or less or when coming to a stop? Diagnostics is showing low voltage to the throttle system. What does this mean?
You have two sensors that activate the throttle; one inside the car mounted on the accelerator pedal and one mounted on the air flow meter.Is there a hour glass shape symbol with a voltage bolt inbetween lit on the dash?
Oct 14, 2010 | 2005 Buick LaCrosse
Copier is locked up with hour glass symbol on screen
Hi info77200,
Unfortunately the hour glass symbol remaining on the screen is indicative of a firmware failure.
Unless you're a real wizard and know how to reload the firmware, you'll need the support of an onsite engineer.
Jan 04, 2010 | Konica Minolta bizhub C250 All-In-One...
I put the battery in it shows no battery symbol on the screen
Hold in Alt, delete in backspace in immediately after putting the battery back in until you get the hour glass.
Apr 11, 2009 | RIM BlackBerry Pearl 8100
Scanner bar seems jammed, printer shows busy, all docs cancelled
Open the printer and pull paper. It might come in pieces then shut down printer to reboot it and that should make the symbol go away and youshould be able to start over. At least when I had a problem thats what fixed it. Hope it helps
Jan 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Power Up Hour Glass appears an stays on for 3 hours
This should help. When the hourglass symbol stays on, press and hold down the start button for at least 15 seconds. The screen should clear and then you can navigate back to the correct opening screen and select music, videos, photos etc. as you require.
Nov 26, 2008 | Archos 405 Digital Media Player
Apple iPod nano Third Gen... Problem
Is that a real ipod? hourglass.. it sound fake to me.
May 30, 2008 | Apple iPod nano 3rd Generation
ZELDA AND THE PHANTOM HOUR GLASS
Close your DS with both the sea chart and crest map displaying.
Nov 05, 2007 | Nintendo DS Lite Console
Samsung DV330AEW Dryer Logo
56 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
