Question about Sewing Machines
On my Pfaff hobby 1142, when sewing buttonholes with automatic buttonhole attachment, the buttonhole is more dense on the left side, than the right side. I've found myself reverse sewing over the right side to make them look close. But this is not right, what could be causing the problem? I've tried changing settings but did not help.
    Champion:
  • 208 Answers
You will need an engineer to adjust the feed from the inside of the machine
Posted on Oct 21, 2013
  • 4 Answers
SOURCE: buttonhole lever
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
Posted on Nov 26, 2007
  • 55 Answers
SOURCE: pfaff hobby 1142. only goes one way, does not
it sounds like the buttonhole mechanism is seized up or gummed up with old grease. try following the linkages for buttonhole mechanism or button to see you can locate the stuck linkage.
otherwise it sounds like a tech job.
scott.
Posted on Jul 28, 2009
  • 48 Answers
SOURCE: My automatic buttonhole attachment won't make
This is not the problem of the thickness, but of the softness. Fleece will pull unevenly, causing the dogs to simply tug at layers of it in place, instead of moving it. You will have to (GENTLY) assist the dogs in moving your fabric, if your fabric is this soft.
The cause of this is 90% on the fault of the fabric, and 10% on the way the buttonholer foot works. The foot is built to hold the fabric fast in place, with sliding action only permitted by the buttonhole guide. However, this is assuming the dogs can get enough purchase to move the fabric around. Simply put, again, you will have to help the dogs along with this one(you will be able to clearly feel the difference and which way the dogs "Should" be moving at the time when you attempt to, as once it catches in one direction, it is likely to keep going in that direction until the dogs stop.)
Posted on Apr 21, 2010
  • 539 Answers
SOURCE: pfaff 2170 will not make consistently sized buttonholes
Go to the following site regarding timing your machine. Are you placing a button in the buttonhole foot so the machine "knows" how long to make the buttonhole? If you have a button stop lever to the left of your needle bar, are you pulling it down and putting it in FRONT of the button stop so it can complete the rotation?
Try www.fixsewingmachine.com
Try http://www.manualowl.com
Posted on Apr 13, 2012
SOURCE: pfaff 2144 won't stitch right side of buttonhole or skips stitches
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
Posted on Jun 11, 2012
I am trying to make a buttonhole for a 3/4" button, using a Pfaff Ambition 1.5. Using the buttonhole attachment the buttonhole comes out to be 3/4 " what am I doing wrong?
Hello, Suzanne -
The buttonhole opening needs to be 3/4". That means the actual button hole stitching needs to be 7/8" - 1/8" larger than the button..
Read the information here:
https://itch-to-stitch.com/proper-placements-buttons-buttonholes/
Best wishes.
Feb 23, 2018 | PfaFF Sewing Machines
Huskystar 219 224 type buttonhole
Attach the buttonhole foot. Then pull down the arm to interact with the foot. It is next to the presser bar to the left. Select buttonhole stitch. Start sewing. It should stitch all four sides in one step.
Oct 13, 2013 | Sewing Machines
Buttonhole feature
try changing the needle
make sure the button hole lever is pulled down, it should be on the left
hand side of the needle, if your machine has one
it's also possible that the machine needs to be checked to see if
there is something wrong with a gear or just needs some type of
adjust inside of the machine
Sep 04, 2012 | PfaFF Sewing Machines
Pfaff 2144 won't stitch right side of buttonhole or skips stitches
SKIPPED STITCHES
Jun 11, 2012 | Sewing Machines
Pfaff 2170 will not make consistently sized buttonholes
Apr 13, 2012 | PfaFF Sewing Machines
Pfaff hobby 1142. only goes one way, does not complete buttonhole.
scott.
Jul 28, 2009 | PfaFF Hobby 4260
Buttonhole on second side was only half the length of first side
Hi, did you buy the machine from a dealer - if so, I would take it back and ask them to show you how to do buttonholes again. It is also possible that, although the test buttonholes sewed out correctly, the automatic button sensor needs professional adjustment.
Before going back to the dealer, find the section in your manual that discusses buttonholes and read thru it very carefully. Pfaff machines are not intuitive, and the manual might describe a way to adjust the automatic buttonhole settings so they sew out correctly.
If you need more help, please repost and I'll try to help or put you in touch with a dealer who can help
Good luck, Ginny
Good luck, Ginny
Jan 08, 2009 | PfaFF Tiptronic 2030
Machine made buttonholes.
Here ya go! For 1 Step Automatic Buttonholes: 1. Place button into the buttonhole attachment. 2. Push slider to hold button securely in the slot. The button goes to the back! 3. Put button foot onto needle bar--just attach it securely. 4. Place needle thread and bobbin thread UNDER buttonhole attachment and let 4"-5" of thread trail behind it. 5. There's a lever called a Button Stop to the left of the needle bar. Give it a gentle tug and pull it down. Pull forward. Hear a click? Now the machine knows what length to STOP sewing! 6. Put foot on pedal and machine will sew barrack closest to you first. It will continue all around until it makes complete rotation of each side. 7. You must do these steps for each of your buttonholes! IMPORTANT: Make sure you set your dial for making buttonhole pattern because that "tells" machine to zig zag, and use appropriate size needle for the particular weight of your fabric. A new needle before you begin is recommended. Turn screw on needlebar to loosen screw. Hold it so it does not slip down into the feed dog area! New needle is inserted flat shank toward back of needlebar as far as it will go. Tighten screw. Did this help? Hope so!
Jimmy
Mar 03, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
204 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
