My little sister's RCA TruFlat 27" TV won't turn on. I don't know it's model number. I have it connected to cable and it works, and I know the wall plug works. The little red light that I press to turn on the TV is off, showing it's on. But there's no images, not even a "CH3" or "Volume(when I change the volume)" image. She says she went on the settings menu and turned on "FSP" or "FPS" and about a minute later it turned off by itself. So I assume it's the cause. Any help please? How can I turn off "FSP"/"FPS"? Will I have to go get it fixed?
  • 2,113 Answers
She changed the Frequencies per second (in the Americas it has to be 60 hertz, In Europe, Asia, and elsewhere it has to be 50 hertz). Changing that will cause the tv to self destruct.
Posted on Oct 21, 2013
  • 102 Answers
SOURCE: technical help
You need an audio y cable - That is a cable with a headphone jack (to plug into the speaker/line out jack on the laptop) and on the other end 2 rca jacks (they need to be plugged into the left and right audio inputs on your tv but make sure it is the same inputs that work with the s-video cable) That should get you sound on your tv. You can get 1 here: http://www.newegg.com/Product/Product.aspx?Item=N82E16812196019 Or pick 1 up at your local $1 store. Or if you have an old pair of headphones, rca jacks and wire you can even make one.
Posted on Sep 17, 2007
quare3
  • 48 Answers
SOURCE: RCA TRUFLAT VOLUME,CHANNELS MOVE ON THERE OWN
i would honestly suggest if you still have the receipt return it back. dont forget your rating thanks.
This is a very common problem for RCA TV. I have one as well. or go to www.tv.rca.com/ there are free manual there
Posted on Jan 25, 2008
  • 899 Answers
SOURCE: Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Posted on Oct 06, 2008
SOURCE: Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Posted on Nov 09, 2008
honeymokey
  • 3113 Answers
SOURCE: My RCA TruFlat 27F520T 27" TV started acting up.
The buttons on the tv are the problem. I clipped the prongs on one of mine and fixed it .Just use the remote now
Posted on Jan 28, 2011
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
I have a RCA TruFlat and it has a fpa lock on and it wont turn on CAN ANY ONE HEL
If you do not have the owners manual GOOGLE THE EXACT MODEL NUMBER WITH MANUAL
Mar 16, 2012 | RCA TruFlat 27F520T 27" TV
On my RCA truflat tv there are solid white horizontal lines going across the top 5 inches of the screen? Do i need to get it repaired or is it a simple problem?
Hello
Your TVs vertical output section has the trouble. Electrolytic capacitors in that section, 8 numbers the most, should be replaced with new capacitors. Iit won't cost more. OK.
Jun 12, 2011 | RCA TruFlat 27F520T 27" TV
My sister was messing around with my T.V. on the menu and did something and now it wont turn on
First things to do : please check your power supply for malfunction and TV fuse for blown.
Jan 17, 2011 | RCA TruFlat 27F520T 27" TV
When I hook up the cable to the RCA truflat tv the screen stays blue. I had it working with a cable box, do you know why it's not working with just the cable?
Your cable system is probably digital, and the tuner in this TV isn't compatible with the system. The cable box output was a regular TV channel 3 or 4 signal the TV could tune in. Without the box, though, your TV's tuner sees nothing. You'll need to stick with the box.
Jan 12, 2011 | RCA TruFlat 27F520T 27" TV
Dec 28, 2010 | RCA TruFlat 27F520T 27" TV
How do I connect a cable box to my TV?
Things you will Need!!!!!
cable box
scart lead
power lead
cable connection coming into your property.
Tv
and last but not least a couple of minute of your time.
the first thing I would do is connect your cable lead F connector (screw on connector) this should be located next to an external wall. they normally put a horrible box on the wall inside your house.
Once this is connected, connect the scart to the box. this is labelled so you carnt really go wrong. then connect the other end of the scart to the scart port at the back of your telly.
last thing you need to do is connect the power cable to the cable box. Then turn it all on.
when you power the cable box up you might have to wait a minute or two just to let it settle then press the power button on the remote this should automatically turn the correct extension on the tv for you.
Hope this Helps you out
Little Dish Fitter
Sep 18, 2009 | RCA TruFlat 27F520T 27" TV
RCA TruFlat Won't Turn On!
Same problem with Sony. Unplug for 36 hours at wall and it should work
Aug 11, 2009 | RCA TruFlat 27F520T 27" TV
Audio set up to xbox 360
There would be a RED,YELLOW,WHITE input cables that you would hook up to the back, there should be a Video mode on you remote turn it to one of the input channels and you should be fine.. Thanks and please rate.
May 21, 2009 | RCA TruFlat 27F520T 27" TV
Unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
Sep 19, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
