Question about ZTE Score
Cant get my internet to work on the phone. Not using wi-fi. Trying to use the internet through my network
    Problem Solver:
  • 12 Answers
You might not be on the right system select, try going to settings>wireless and networks> mobile networks> make sure your data is enabled and data roaming is on in system select make sure its on home only, if your running through cricket, after you make any adjustments go to your dialer and call *228 let it reset (will not lose anything) and your should get your internet access back (worked for Cricket for a long time I know the phone well)
Posted on Nov 03, 2013
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
My wifi stop working,i dont know why???
Solutions to Common Android WI-Fi ProblemsFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up. I usually fix their problem after few troubleshoots but today while I was fixing a problem on my device, I realized that it could happen to any one - even to my readers on Guiding Tech. Hence we are going to discuss four of the most common Android Wi-Fi problems and see the probable causes and solutions to them.
Android Cannot Scan a Wi-Fi Network Reason
There may be two reasons as to why your Android cannot scan a network automatically. The first reason may be that the network you are trying to connect to could be Ad-Hoc in nature. As most of the Android phones are not configured to work on Ad-Hoc networks but on access points, they don't scan them.
The second reason may be that the Wi-Fi network you are trying to connect to might be hidden for security reasons.
Solution
By default, Android does not support Ad-Hoc Wi-Fi network but many developers patch the wpa_supplicant file on Android in order for them to work. If you do a quick Google search you will be able to find if there's a fix available for your device but the fix can only be performed on a rooted phone. Furthermore, don't forget to back up your original wpa_supplicant file if at all your phones goes into foreclose or boot loops.
If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
Wi-Fi Keeps Disconnecting Frequently Reason
The most obvious reason for the problem may be with the Wi-Fi Sleep Policy which disconnects your Wi-Fi every time your Android goes to sleep to save your battery's juice.
Solution
To manage Wi-Fi Sleep Policy, open Advance Wi-Fi settings on Android and tap the option Keep Wi-Fi on during sleep. Here, check the option Always to enjoy an uninterrupted connectivity, but you will have to compensate it with your battery life.
If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
Obtaining IP Address Infinite Loop Reason
I don't know the exact reason behind this, but it might be a bug in Android. I have seen many people getting this problem, and it gets kind of annoying when the problem does not gets fixed even after restarting the device.
Solution
First of all, you must restart your Wi-Fi router and see if that helps. Many people say that resetting the phone to factory state works but that's not an appropriate solution. Wi-Fi Fixer is an amazing Android app that can help you here. The app resets your Wi-Fi system files (same as when you reinstall the Wi-Fi drivers in Windows, or you disable and enable the Wi-Fi adapter) and services and helps you to connect to the network and obtain the IP address.
Solutions to Common Android Wi-Fi Problems
Ads by Google
    wifi-router.pngFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up.
    Solution
    ad-network-manually.png If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
    Solution
    Ads by Google advanced-settings.pngkeep-wifi-on.png If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
    Solution
    wifi-fixer.png If you know the range of IP address the router is broadcasting, you may configure your Android to use static IP address while connecting to the network.
    Can't Connect to Internet using Wi-Fi Reasons
    There may be several reasons as to why you are not able to connect to the internet even when you are connected to the Wi-Fi. The reasons may be:
    • The router is not broadcasting internet services.
    • The IP address or the gateway is wrong.
    • Problem with the DNS settings.
    Solutions
    You may use another device to check if the router is actually broadcasting internet. Also you can configure the IP address, the gateway and DNS manually to connect as their might be problems with DHCP.
    Conclusion These are pretty much most of the Android problems one might encounter on his device and the probable solution one can try to fix the problem. I don't guarantee that you will fix the problem but it's a good start nonetheless. And most of the solutions should work actually.
Thanks .
Sep 03, 2013 | Cell Phones
Im on aol my internet works on the pc but my phone cant even find the wifi at all
Is there the wi-fi facility on your phone. If yes, look either its enabled or not and then search for the wireless network near to the router or access point you will get the network list wi-fi is enabled on your phone.
Apr 14, 2013 | Computers & Internet
I cant get my tablet to connect to wifi
Android tablets, unlike Android phones, don't require mobile phone service or a contract with a mobile phone company, and several models use Wi-Fi for network connectivity. The Android 3.0 operating system, known as Honeycomb, is designed specifically for tablets, and has the same features for Wi-Fi connections that are available with earlier versions of Android. Android tablets support wireless connections encrypted by both WEP and the more-secure WPA.
Tap the "Apps" menu on the tablet screen. Touch "Settings." Touch "Wireless and Networks" and select "Wi-Fi Settings." Tap the "Wi-Fi" box to turn on Wi-Fi. The Android tablet scans for available Wi-Fi networks and displays them on-screen under "Wi-Fi Networks." Tap an available Wi-Fi network. Touch "Connect" if it is unsecured, or enter the password or passcode for the encrypted connection.
Tap "Connect."
Jan 14, 2013 | Polaroid 7 in. Internet Tablet
I cant get an internet connection on this phone, do i need to set it up manually?
There are two ways you can connect to the internet over your phone. You can purchase a data plan from a company like AT&T which you can use anywhere. The other option would be to use your phone to connect to a wireless access point(WI-FI).
What are the differences? Wi-fi is usually free unless at a cofee shop etc but has a smaller area in which you can access(you have to be within a certain distance of the wireless router). A data plan cost money and is typically slower, however, you can use it at anytime as long as you have a signal on your phone.
You can click here to access the user guide for your phone.
If you have a data plan purchased and are using the SIM card they gave you then whenever you use a application on your phone that requires internet access it will connect.
If you go to page 83 of the manual it will go over the steps you need to take to enable Wi-Fi. In short, first active Wi-Fi
1) In Idle mode, open the application list and select Settings
? Wireless and network ? Wi-Fi settings ? Wi-Fi.
1) Then under Wi-Fi settings click Wi-Fi networks, select the Network you wish to connect to then click Connect.
Reference the user manual as it goes into more details about the features on your phone and how to use them.
Regards,
G33k
Jul 29, 2011 | Samsung Galaxy S GTI9000 Smartphone
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
How we connect internet to iphone
The iPhone can connect to the internet through both Wi-Fi and EDGE. Wi-Fi would be the wireless network at your home or business. When the iPhone connects to the internet through EDGE, it is actually connecting through the AT&T phone connection (or any other service provider the iPhone works with in the future).
safari.jpgTo the connect to the internet, you simply need to open up Safari (which is the internet browser used by the iPhone). If you're used to using a pc, think of Safari as the 'Internet Explorer' that the iPhone uses. You can use Safari the same way you could use Internet Explorer.
Once you open up Safari, the iPhone will attempt to connect to the internet. If there are wireless networks available wherever you happen to be, the iPhone will prompt you to choose one to connect to. If you're trying to connect to a network that has security, you will be prompted to enter the password for the network.
If you want to check to see whether there is a wireless network available where you live, work, or play, go to 'Settings' and then 'Wi-Fi'. The iPhone will show you all of the wireless networks that are available.
If there aren't any wireless networks to connect to, iPhone will connect to the internet over EDGE. Connection speeds over EDGE will likely be somewhat slower than they would be over a Wi-Fi network. You will also not be able to answer phone calls while connected to the internet through EDGE. If the iPhone is connected to the internet over EDGE you will see this small icon at the top of your screen: edge-icon.jpg
for more information you can go thru this link
http://support.apple.com/kb/ts2756
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 29, 2010 | Opera Software Mini
Ipod wi fi conection
Wi-Fi Functionality
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
Networks
con el servidor remoto
Aug 28, 2008 | Sony Ericsson P990i Cellular Phone
ZTE Score Logo
63 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
