Question about Jenn-Air 30 in. CCG2423 Gas Cooktop
Gas Kleenmaid cook top, one igniter continues to
Gas Kleenmaid cook top, one igniter continues to click even without gas on . Need to turn off power supply to stop . If power supply is turned back on igniter begins to click & spark
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
The switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Posted on Oct 23, 2013
5 Suggested Answers
  • 833 Answers
SOURCE: Igniters will not turn off
Your switch assembly on the valve shaft has come loose or has broken. Have a look.
Posted on Jun 15, 2008
SOURCE: spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Posted on Mar 09, 2009
  • 222 Answers
SOURCE: turn on one burner, second burnertrise to light
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
Posted on Sep 16, 2009
localwonder
  • 6784 Answers
SOURCE: all cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Posted on Nov 04, 2009
One of the burners ignition will not turn off - it continually is sparking - i have to turn off the elec supply to stop the ignition ? any ideas
Hi and welcome to FixYa, I am Kelly. On the burner your having problems with the ignition control switch located in front of the gas control vale on the stem has failed. These are cheesy little switches that are thin ceramic with nothing but 2 strips of copper inside them. One piece is fixed and the other piece is movable by the ceramic switch cam. If the movable copper arm or fixed copper strip gets bent the ignition will not shut off. Also if the ceramic cam of the switch fractures it will cause the switch to stay actuated. The gas valve has to be disconnected and removed to change the switch on most units. The wires in the switch have to be unlocked by inserting a jewelers screwdriver into the holes in the switch body to release the wires. These switches are common to most every gas cook top models no matter the brand. Without your model number I can not provide you with the manufacturers replacement part number. Change the burner ignition switch on the front of the gas valve for the burner with the problem and it will work fine.
Thanks for choosing FixYa,
Kelly
Mar 05, 2011 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Miele Gas hob KM326G 2 burners won't stop clicking
Hello Leighvz,
The rings around the burners should be cleaned periodically. Each one has a series of holes to let the gas come out and have to be set back perfectly or else you will continually have this problem. You can clean with regular dish soap an water and a sponge or rag.
Also, If you put a pot or pan on the burner and it is too large it will cut off oxygen to the burner causing your clicking. The clicking only occurs when the oxygen supply is not enough. Hope this helps
Sep 07, 2009 | Miele 35 in. KM326G Gas Cooktop
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Gas cook top
thanks for the question yes some stoves do this and its normal when the burner you selected lights turn to low or hi the igniter will stop they do this to save on igniter modules thanks the appliance doc
Sep 16, 2008 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Spark continuously on
If you have recently cleaned it, you may have gotten moisture behind the knobs and into the spark switches. Be very careful not to let moisture get behind knobs. Very dangerous. If this is the case, they may dry out themselves and stop sparking. If not you may need to replace a spark switch behind knob.
Nov 20, 2007 | GE 30 in. JGP336 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Jenn-Air 30 in. CCG2423 Gas Cooktop Logo
116 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
