Dell B1160w won't pull paper in to print
Traded HP LaserJet 1200 to inlaws for their B1160w. Got the Dell home, installed it. Paper jams when printer tries to pull it in. Looks like it's being pulled unevenly. Tried more than once. Pulled each "jammed" sheet out and each one is bent in about the center of the page.
pattersj78
  • 70 Answers
SOURCE: Dell printer problem
Sounds like you may need to replace the pick up rollers on the machine.  Without knowing exactly where the jam error happens during the print process, it's hard to say.
Posted on Oct 19, 2007
RPFinney
  • 385 Answers
SOURCE: paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Posted on Apr 21, 2009
SOURCE: HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Posted on Aug 31, 2009
  • 52 Answers
SOURCE: My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
Posted on May 10, 2010
  • 10406 Answers
SOURCE: paper is pulled into printer unevenly causing paper jam
Look closely at the "path" that the paper takes through the printer -- you probably have a small piece of paper stuck somewhere, that is causing the paper-feed to get "skewed".
Failing that, take the printer to a qualified technician.
Posted on May 27, 2010
Orange light on my dell b1160w means what?
paper jam, if its blinking needs firmware update
Jul 09, 2017 | Dell Computers & Internet
HP LaserJet 1020 paper jam alert
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fixing a Paper Jam - HP LaserJet 1020 Printer
Apr 17, 2013 | HP LaserJet 1020 Printer
Paper jam in HP 1200 printer
Hi,Make sure you got every single piece in there, and if you can't get it to work, just hard reset it. Unplug it from the wall wait 5 seconds, plug it back in. Should be good as new.
The LaserJet 1200 has two paper inputs, a regular paper tray and a priority input tray that is used for envelopes, labels and transparencies.
Paper jams rarely happen with the HP LaserJet 1200. If you can see paper sticking out of the input or output tray, try to remove it gently. If you encounter resistance or if the page tears, turn off the lights in the room to avoid exposing the toner to light. Open the toner door, which is above the paper tray, and the output door, and rotate the green levers down. At this point, you might be able to remove the jammed paper. If not, remove the toner cartridge.
Grasp the page in both hands and gently pull it free. Replace the toner cartridge and close the doors. The cartridge and the levers will slide back into place.
Hope that helps..
Mar 15, 2011 | HP LaserJet 1200 Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
Paper printing and get stuck n when i print only 1 page, it grab until lot of paper n suddenly jammed.. what is the actual problem what should i do? hp laserjet 1200 series
sir
I guess you maust replace your Suser Assembly, or at least regrease the fuser roll.
try to go to service center , or download the service manual from the internet
regards
walid sayed
Egypt
Mar 16, 2010 | HP LaserJet 1200 Printer
Aug 31, 2009 | HP LaserJet 4L Printer
My hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Jun 22, 2009 | HP LaserJet 1150 Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
557 people viewed this question
k24674
jasbo
jasbo
