Question about Sony Vpcee22fx Vpcee Cpu Cooling Fan Heatsink 3fne7tan030
I need identify the sony vaio Vpcee22fx fan/heatsink model - motherboard Dane7mb16e0 Amd
    Sergeant:
    Champion:
  • 272 Answers
Sony VPCEE22FX VPCEE AMD Motherboard DA0NE7MB6D0 w/ FAN + HEATSINK a1784741a
Posted on Oct 22, 2013
Sony vaio VPCEE22FX fan won't star but have power light?
You have not given enough info so I'll shoot from the hip. If all you are getting is a power light and no BIOS post the chances of a bad video processor ranks extremely HIGH. Solution..Reflow the soder and replace that stupid thermal foam with a copper shim
Nov 01, 2013 | Sony VPCEA21FX/WI VPCEA22EG/WI VPCEA22FX/B...
Tip
How to Remove a AMD Processor
<p>Removing a processor AMD is a work that can only be done with a screwdriver in less than 30 minutes. The processor AMD is a central processing unit (CPU) with 939 pins, which are connected to the motherboard. Removing the processor is an issue to withdraw from the motherboard with your hands after you remove the heatsink from the chip.<br /> <p> <br /> <p>1. Turn off the computer and unplug the power cord before removing the AMD processor. Unplug the connector on the back of the computer case and remove the screws, the lid of the computer, in the case with a screwdriver.<br /> <p><br /> <p>2. Slide the computer cover and set aside. Pull the cord that connects the heatsink fan on the motherboard with one hand.<br /> <p><br /> <p>3. Lift the lever on both sides of the fan heatsink, so straight up and remove the plastic clips on the sides of the sink on the motherboard.<br /> <p><br /> <p>4. Pull the heatsink and fan on the motherboard and set it aside.<br /> <p><br /> <p>5. Lift the AMD processor motherboard and carefully remove it from the computer.<br />
on Jun 21, 2011 | Computers & Internet
Need a heatsink that will fit MSI 870-G45 Motherboard (Model # MS-7599). CPU is AMD Phenom II X4.
You can find heatsinks at the following link, you will need one that is compatible with
AM3 AMD 770 ATX AMD motherboards
If you look through each product, it will show you compatibility or you can filter search results.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=574&name=CPU-Fans-Heatsinks
Regards,
G33k
May 05, 2011 | AMD Computers & Internet
My sony vaio VGN-CS215J cooling fan is to noise I dont no what to do
remove the covers and clean the fan with a brush for dust remove the heatsink and clean the surface and apply athin layer of heatsink solvent and fix it firmly in the processor
Mar 28, 2011 | Computers & Internet
Hello, I have a vgn-s170 laptop that I just installed a new screen and motherboard. the video chip heatsink/fan is not running and the screen does not come on. what can i do
Have you tried connecting it to an external monitor? Are you sure the heatsink fan is not defective? If the screen works on an external monitor you know the video card is good. As long as the cable is plugged into the motherboard to provide power for the heatsink then it's either a bad heatsink fan or the motherboard connector for the heatsink is bad. My money is on the heatsink fan if you can get video from an external monitor.
Jul 30, 2009 | Sony VAIO VGN-S170 PC Notebook
Sony Vaio PCG-K30 laptop does not work
By removing the heatsink and cleaning it, you may have wipe d the heat sink compund, or the heatsink is not well attached to the base and is not making full contact with the CPU.
Check for this two conditions, and correct them.
Everything should be fine.
Jun 10, 2009 | Sony (B99860307) for VAIO PCG-K series...
I need to change the processor fan in my mothers sony Vaio desktop, but I can't figure out how to access it.
Pop the side of the case off, it either uses screws or has plastic retention system. Then you will see a main fan over the CPU heatsink. Unscrew or unclip the fan. Install the new fan. If the fan is literally attached to the heatsink and cannot be removed then you will have to buy a whole new heatsink from www.newegg.com 10-30 dollars (comes with a new fan as well). If you remove the whole heatsink make sure you have thermal paste to reapply to the processor and heatsink. If you email me a picture of the inside of the case i can help you. letzfly777@gmail.com Hope that helps!
Jun 04, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
Sony Vpcee22fx Vpcee Cpu Cooling Fan Heatsink 3fne7tan030 Logo
70 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
