Question about HP Pavilion a1220n (A1220NED904AA) PC Desktop
Had to change out my case when power button broke new case has different wiring need help new case is a enermax (ostroge)
    Master:
  • 359 Answers
You will have to look at the motherboard manual to find out where each cable needs to go. I assume you are referring to the power button, reset button etc. cabling. There are generally a set of pins on the motherboard that run next to each other and are for all of the button on the case and LEDs etc. In order to find out this information you need to get your exact motherboard model number and look for its manual online. it will tell you the details of each pin and where the cabling goes.
Posted on Oct 20, 2013
    Problem Solver:
  • 10 Answers
Here you go: http://www.findlaptopdriver.com/ptgd-la-front-panel-motherboard/
Posted on Oct 31, 2013
The big fan on the side isnt working
Does it have power to it? Check the power connector and try a different socket or plug.
Does the fan spin freely? If not its jammed. You can try to unstick it but it will probably never work properly (but hey! it doesn't work at all now, right?)
Sep 25, 2013 | Enermax Phoenix Neo ECA3162-B black/red
What fuse is in a Enermax EG495P-VE Noisetaker 485W Power Supply
Just buy a new power supply. If you touch the wrong thing inside that psu you will die. Seriously.
Aug 15, 2012 | Enermax (by Coolergiant) EG495P-VE SFMA...
How can I test voltages on the Enermax Galaxy EGA1000EWL 1000-Watt Power Supply unit out of the computer.
Most motherboards will give tell you all of the voltages being provided by the power supply in the bios under hardware or health monitoring section. Otherwise you will need a multimeter to test the different voltages. You would want to set the multimeter to the 20v or similar setting. Depending on what voltage you would want to test would determine the color of wire you would check. You would connect the black/negative/ground lead of the multimeter to one of the ground wires coming from the power supply normally a black wire. The 12v is normally a yellow wire, the 5v is normally a red wire and the 3.3v is normally an orange wire. The wires may be different colors so you may want to look up the ATX pinouts to find the exact voltages you want to measure.
Feb 23, 2011 | Enermax Galaxy EGA1000EWL 1000-Watt Power...
My computer will not power up at all been looking for another compatible power supply since this one is discontinued need help immediately.. enermax eg425p-ve
I'd check into a DiabloTek PHD650 650-Watt Power Supply. It's a higher voltage module, but has similar features to your Enermax power supply. If you can't find it locally, check out TigerDirect.com (my fave) or NewEgg.com. These two sites are likely to have these, and are competitively priced.
Aug 31, 2010 | Enermax Noisetaker EG425P-VE...
My enermax power pack sparked out of the fan in the back and now my computer wont turn on. Not sure if it's the power pack or the board is fried... Any help would be appreciated thanks =)
if it sparked then something inside the power supply malfunctioned and that is the reason it wont work. You will need to replace it. Unlikely that it fried your board in the process. You can test this by swapping the power supply with one that you know works.
May 20, 2010 | Enermax EG301P-VB (eg301vb) Power Supply
Hi, I have a problem with my Enermax Blue Viper CS-718-B, bought in 2006. When pressing the start button, the light and fan are working very short, or I get a peep, but the computer is not booting. Only if...
Your computer either has a fault with the power button in which you can request off the manufacturer a replacement (may cost money depends on warranty) or you do not have enough power for the computer components. Try removing all the peripherals except from screen, keyboard and mouse and then try booting. If it works then you dont have a large enough power supply for all the equipment you have. If it still does not work then it could still be a power supply (PSU) fault in which you can take the psu to your local computer store and they can test it for you.
hope this helps
Oct 08, 2009 | Enermax (CSXSEG718SNP) ATX Full Tower Case
Case tranfer
Yes your motherboard will be compatible in the new case.
Please vote if this helps!
nLinked
Computer Support Services
Jun 07, 2009 | ASUS P5PE-VM Motherboard
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
HP Pavilion a1220n (A1220NED904AA) PC Desktop Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
