Question about JUMP START SYSTEM
Need power cord to recharge - JUMP START SYSTEM
    Champion:
  • 473 Answers
Contact the manufacturer.
Posted on Oct 21, 2013
Braun 7series will not recharge yet will work because she still has power in it what can I do when the charge finishes
If it is not recharging, you have a problem with the cord or the charging system (circuit board). You will need to determine which.
If new cord is needed, you will find at shaveroutlet.com.
You will need to know your specific model number is circuit board is needed.
Braun Replacement Charging Cord for Pulsonic and Series 7 Models and More
Jan 02, 2017 | Braun Health & Beauty
Veco 11 300 amp jump start system power supply
recharges from standard AC
Use an w\extension cord
Oct 05, 2014 | JUMP START SYSTEM
Adapter for panasonic hair clipper ER147
panasonic ER147 hair clipper adapter is AP-22290 charger power cord replacement recharge adapter 220 volt for panasonic er147 national or panasonic hair clipper.
http://www.menelectricrazor.com/panasonic-er147-charger-power-cord/
Jan 13, 2013 | Health & Beauty
Shaver won't recharge
If this is the case your Rechargeable batteries (built in) could have been dead..and needs to be replaced.Normally they die in 2 to 3 years depending on the frequency of usage.
But before taking it to a repair shop ,make sure you check the power cord as well,because sometimes one of the lead cracks at the point that it attaches to shaver for charging,which the power cord needs to be replaced.
If you wish you can describe the problem more details than I may suggest something else.
Regards.
Apr 17, 2010 | Braun 360° Complete Electric Shaver
The PSP won't recharge
Hello :
First you need to check the charger . If charger is working fine , then check the power cord . If the power cord is working fine , then the problem is that the battery is dead [ can't be recharged anymore ] . You need to replace the battery in a such situation .
If it's none of that , then I recommend you to replace it , if you still have the guarantee . Or just take it to the service .
good luck .
please rate !
Mar 30, 2010 | Sony PlayStation Portable (PSP) Slim...
7526 twist cord and razor speeds up
Based on the limited info provided, it appears you have a rechargeable razor that you plug in to recharge.
I had this occur with an older shaver I had years ago. The suspected issue is tha the battery isn't fully charged and the razor is running on battery power while the cord is plugged into it and the power outlet.
However, the cord is making a loose connection at the razor or has a broken conductor in the cord. So and what is happening is that you arfe getting an intermittent power connection that allows the power to run the razor, which would be why it seems to "speed up" as any rechargeable product always run faster/better when connected directly to an electric power source.
You can look at the plug on the razor to see if the pins/connector is loose, and also carefully check the cord to see if shows signs of having been sharply kinked or bent at the razor plug end or at the power plug end or along it somewhere.
It could be as simple as replacing the power cord. Or you may have to take the razor apart to repair the charging socket at the razor to resolve this issue.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Health & Beauty
Recharge Stand for Hair Clipper
This link looks promising, but you may have to consider purchasing a new one, hopefully not! I would assume that this one has such a lower price than the rest and lists contents as "charger" so I assume it contains the charger only. Hope this helps
buy power cord for Panasonic cordless Hair clipper ER152 Google Search
May 22, 2017 | Health & Beauty
Palm Tungsten E2 won't work after power cord is removed.
The traditional steps for resetting charging problems are:
1) press reset /while/ the power cord is plugged in
2) unplugging the battery for about 30 seconds, then plugging it back in
You have done #2, but I do not know if you have done #1. Try it, then try to recharge again. If that fails then you probably need a new battery. I have found them on eBay before.
Feb 22, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Lost power cord
Was reviewing some unanswered posts and came across your concern.
Should you still be interested, here is PVS12701 AC Adapter with Power Cord.
You can also try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger's cord for the TruTech PVS12701B.
Additionally, you may want to contact the manufacturer direct.
ALCO Electronics, Inc.
8392 Six Forks Rd., Suite 104, Raleigh, NC 27615,
(800) 252-6123)
Should you need direct Customer Support, please try here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 15, 2007 | TruTech PVS12701 Portable DVD Player
JUMP START SYSTEM Logo
20 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
