Question about Philips Magnavox 9P6034C 60" Rear Projection Television
9p5544c102 Horizontal bow
My 55? projection TV top of picture is bowing down and the bottom is bowing up. There is also a very pronounced shadow in the picture. I have not been able to find a service manual for this model#.
  • meoff Oct 04, 2007
    If someone knows were I can get a service manual that would help. I replaced both ICs #STK392-110 and checked all resistors and 3 fuses, they are all good. When I go into setup to align the cross hairs I don?t see any blue at all, the word blue does not even show up in the text line. The red shows up brightly but I cant move the cross hairs. What do I look at next?
  • meoff Oct 26, 2007
    As stated in my last comment I have done the recommended repair to the convergence board and that did not fix the problem.  To eliminate the convergence board as the problem I put it in a known good TV and it worked perfectly fine.  So now we can move on with other possible causes.  I think that the fact that there is no blue at all on the convergence alignment screen is a clue.  When I look in the back of the TV the bleu gun is lit up but there is no blue on the screen.  Maybe there are to problems one for the hour glassing and one for no blue color.
  • 143 Answers
Lookin the main power supply check for pico fuses somtimes they go bad, turn up your sreen voltage on your blue look see what kind of pic it gives you
Posted on Nov 03, 2007
  • marco amezcua
    marco amezcua Nov 03, 2007
    if you have bowing on the sides of your tv that is horizontal bowbowing on top and bottom that is vertical bow side to side that is pin cushion problemcheck for bad solder connections
  • 105 Answers
Is the blu crt even turning on
Posted on Oct 13, 2007
  • 790 Answers
Ok meoff check the convergence circuit. shadow in the picture is defective convergence circuit... replace a new.
Posted on Sep 28, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Sep 28, 2007
    replace a new one convergence IC.
    carlos fernandez Jr. Oct 07, 2007
    check small parts in convergence section like small capacitors!
SOURCE:
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
Ws55809 tv picture bows at top and bottom. Also has shadows. Is it the bulb and where do I get one.
You have a convergence problem. The 3 picture tubes are fine. The small signal module needs reworked. The board with all the rca jacks.
Nov 29, 2009 | Mitsubishi WS-55809 55" Rear Projection...
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Mitsubishi TV Picture Bowing
You will find a very good guide here and here to fix your TV.
This might not be a DIY if you do not feel comfortable. The repair shops charge about $350.00 to $400.00 for this type of repair.
Apr 19, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Horizontal bow and shadow
Replace convergence IC's--then re-check convergence alignment in servicer mode,if necessary.
Sep 27, 2007 | Philips 9P5544C 55" Rear Projection...
Bow at top and bottom of the screen
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jan 10, 2007 | Samsung HCM5525W 55" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
248 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
