Question about M&S Systems dmc1 Music/Communication System Master White for home se
No power to the DMCI master. - M&S Systems dmc1 Music/Communication System Master White for home se
    Top Expert:
  • M&S Systems Master
  • 12,223 Answers
Reset the DMCI master, test the power cord+power switch for faulty and replace use the multimeter.
Read your owner manual or download from www.retrevo.com
God bless you
Posted on Oct 21, 2013
2004 nissan sentra power windows not working. Replaced door master switch. Replaced power window relay. Replaced 30 amp fuse under the hood.
Look for broken wires in the driver's door opening. If you don't find any, you will need a test light or voltmeter to check for power at the driver's door master switch. For any electrical testing problem, you really need a voltmeter. You can check for power to the master switch on one single wire, with key ON. You can also use the multi-meter to check the ground for the power windows right at the master switch.
Jan 26, 2018 | Nissan Cars & Trucks
How can i unlock my flip phone without erasing its pictures and contacts
Try connecting to usb on PC and look for a file dmci file and hopfully you can save there
Sep 03, 2016 | Samsung Gusto 3 Verizon CDMA Page Plus No...
Return Sharp XE-A102 cash register to factory settings
MASTER RESET
Master reset: Clears all the memory and initializes each preset parameter. The master reset should be performed by using the following procedure.
1. Turn off the power (Power OFF). (See Note 1.)
2. Remove the memory back up battery from ECR.
3. Turn the mode switch to any position other than Power OFF.
4. Turn on the power (Power ON). (See Note 2.) When the master rest is completed, the buzzer sounds three times.
5. Install the memory back up batteries back into the ECR. The master reset can also be accomplished in the following case. (See Note 3.)
Note 1) Power OFF: Means disconnecting the AC power supply to the machine. (Specifically, unplugging the machine.)
Note 2) Power ON: Means connecting the AC power to the machine. (Specifically, plugging in the machine.)
Note 3) In case a power failure occurs when the machine has no battery installed, the master reset operation is automatically performed after the power has been restored.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 05, 2016 | Sharp XE-A102 Cash Register
Grounding problem with my power window motor on a 1997 chevy camero
Test the MASTER switch at the drivers side. It seems to be a "wiring problem with the Master switch. The master switch is the switch that controls ALL the cars windows.
The passenger window switch gets both power and ground from the master switch. You have replaced the passenger side switch and it still had the same result and if the wiring is good from the master switch to the passenger side switch, then the only thing left would be the power window master switch. Check all wiring of the Master switch. That's the only thing that's left to do.
Mar 17, 2014 | Chevrolet Cars & Trucks
No power to power windows
Have you actually checked for power at the driver's master switch?
I don't think there would be a window relay, there is probably a power window circuit breaker in the instrument panel fuse box.
If no windows work, pull the master switch out and check for one hot wire with key on. If none, check for broken wires in driver's door opening. Your ground for the windows will be in that group of wires too. Both must work for windows to operate. If you have power and good ground at the master switch, and no windows work, probably a bad master switch.
Jan 15, 2014 | 1986 Cadillac Eldorado
1990 Corolla. None of Power windows operate from master switch at driver's door, or from local switches at each door itself. Cannot find fuse labeled for power windows (ie PW). All fuses read good
Hello. Welcome to FixYa.
The most common cause of this issue is a bad master switch on the driver side door. Another common cause is a broken power wire that powers up the master switch. CHeck the wries on the connector of the master switch with a 12 vlt DC testlight, with the key on. If you have power, the wire is good, and the switch is probably bad.
Oct 03, 2011 | 1990 Toyota Corolla
What if I erased the...DMCI folder in my memory card? I can no limport my pictures in my desktop because there is nothing in my memory card..
It is not recommended to erase the DCIM Folder in the Camera as this is the root directory in the Digital Camera which contains DCIM (Digital Camera images). This DCIM Folder contains the sub directory where the images are getting saved. if the folder is deleted manually from the Computer, then the Camera will not recognize the Memory Stick inserted and the Computer also. if the folder is deleted or edited, then I suggest you to Format the Memory Stick again in the Camera using the Format option in the Menu of the Camera.
Thanks for using Fixya.
Jan 27, 2011 | Cameras
Need to do a master reset and it ask for the master code. Dont know it.
There is a way to do a Master Reset on MOTO Q phones that cannot access the standard Master Reset method:
  1. Power off the Q
  2. Press and Hold the Center Select Key, while powering up the phone
    or
    Press and Hold the Z & E keys, while powering up the phone
  3. The MASTER RESET screen will appear
  4. Press Yes
  5. This will restore the phone to factory settings
Oct 05, 2010 | Motorola Mobility Q9 Cell Phone
How to replace master cylinder. what is the relationship between it and the power steering?
If you have a hydor booster the power steering pump runs your power brakes, make sure power steering level is at max, to replace master cylinder, unscrew both brake line, then unbolt both nut that hold master cylinder 15mm nut's, remove master cylinder, fill new master cylinder with DOT 3 brake fluid, bench bleed new master cylinder, new master cylinder will come with a bleeder kit, before installing, then install new one.
Jan 28, 2010 | 1997 Chevrolet Astro
Wat is the code of formatting motoq8
To Perform a Master Reset or Master Clear:
  1. Press Start
  2. Scroll to and Select System Tools
  3. Scroll to and Select either Master Reset or Master Clear
  4. Press Yes (Left Soft Key) when Alert appears
  5. Enter Master Code (normally 000000)
  1. Power off the Q
    or
  4. Press Yes
Dec 20, 2009 | Spectec SDW-822 WiFi 802.11b MiniSD Mini...
M&S Systems dmc1 Music/Communication System Master White for home se Logo
43 people viewed this question
Top M&S Systems Televison & Video Experts
Are you a M&S Systems Televison and Video Expert? Answer questions, earn points and help others
