Question about Kenwood Hand Blender Set kMix HB790, White
I can't get the gasket out of Kenwood kMix blender, does anyone know how to dismantle it?
Want a seal for kenwood blender model bl300
That kenwood is a UK model so if your in the US it's tough to source. The ring you need should have an outside diameter of 76 mm and an inside diamete of 56 mm.
This is a uk ebay link with the exact part.
1 Kenwood BL300 Blender Liquidiser Rubber Seal Gasket
This is a us amazon link with something that might work but not exact. There is a uk amazon equivalent if that works better for you.
Amazon com kenwood blender seal
Feb 18, 2015 | Kenwood Blenders
How to
I would suggest just replacing it. It can become a shock hazard in its current conditon.
Jul 23, 2014 | Kenwood kMix BLX50 Blender, White
How do I open a Kenwood hb720 triblade hand blender to replace the motor?
need instructions on how to put a sg500 together
Oct 23, 2013 | Blenders
How to dismantle hand blender kenwood kmix?
hi there, i have one of these and am quite tech savvy and want open
the sucker up and see whats wrong. Just would rather open it with
minimum damage to the casing.
Is there a way i can private message you my email address?
thanks
Dan
Sep 03, 2012 | Kenwood Hand Blender Set kMix HB790, White
Dismantle my kenwood sb200
can you please send a copy of the instruction to me as well at hrd@qtcst.com. Thanks...
Jun 03, 2012 | Kenwood SB206 Smoothie Pro 3Speed Blender
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Kenwood Hand Blender Set kMix HB790, White Logo
54 people viewed this question
Top Kenwood Blenders Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
